PWM ouput directly from MIAC Arduino
Monie Jacobsen
Has thanked: 17 times
Been thanked: 46 times
Post by Monie Jacobsen »
Hello everyone
Can I make PWM ouput directly from MIAC Arduino
Type: MI5466 AVR ATmega1281
How can PWM ouput made?
Like a small code eksemple!
The example below does not work in MIAC Arduino.
Attached:
MIAC PWM TEST.fcfx
(7.55 KiB) Downloaded 435 times
Best Regard
Monie
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: PWM ouput directly from MIAC Arduino
Post by LeighM »
Hi Monie
Motor 1 (PB7) is an enable signal for outputs A and B
So you also need to set A and/or B.
So just add for example OutputON(1)
Hope that helps,
Leigh
MIAC PWM TEST.fcfx
(7.74 KiB) Downloaded 415 times
Monie Jacobsen
HI LeighM
On the oscilloscope I can not see anything PWM ouput A or B
I use your example!
User Flowcode v7
Best Regard
Monie
LeighM
Post by LeighM »
Hi Monie,
That is very strange.
Could you post your generated C file "MIAC PWM TEST.c" and I will see if there are any differences with mine.
If you just have a loop with a delay and OutputON(1) delay OutputOFF(1)
and no PWM, does that give an output?
Also could you check the PWM component has a valid prescaler setting on your project.
Leigh
Monie Jacobsen
HI LeighM
Hendes ER C-fil "MIAC PWM TEST.c".
Attached:
MIAC PWM TEST.c
(41.45 KiB) Downloaded 452 times
Best Regard
Monie
LeighM
Post by LeighM »
Hi Monie,
I think the issue is that the default prescaler value for the PWM component is not valid for the ATmega device.
So you need to change it with the drop down list.
Hope that helps,
Leigh
Monie Jacobsen
HI Leigh
OK with the "default prescaler".
I write prescaler manual.
Thank you very much.
GO'Weekend
Best Regard
Monie
