Hi All!
I have bougth a KS0108 display. And I have made a very simple test program but did not manage to get it work. nothing happen on the display..
http://www.ebay.com/itm/191943363919?_t ... EBIDX%3AIT
I have checked the connection many time, and adjust the contrast and also update with Ben´s new update.
Has anybody here experience and tryed to us FC7 with this display? In that case, could you please check my simple program (config)
I use an Arduino Mega 2560
Thanks in advance.
Jorgen
KS0108! Display Solved!
- Has thanked: 1135 times
- Been thanked: 299 times
- KS0108 Test.fcfx
- (6.8 KiB) Downloaded 287 times
Re: KS0108! Display
Hello. I Test the Programm on a PIC ( i dont have AVR Lizenz). I change the "Transparent", in the Component Macro, from 0 to 1 - look at the second Picture.
Did you change the contrast higher? Is the display darker?
You need a potentiometer between Vout (Pin 18) and GND (Pin 1) and the grinder to Vo (pin 3), then you can change the contrast - Look at the first Picture
- (124.14 KiB) Downloaded 2636 times
- (435.72 KiB) Downloaded 565 times
Re: KS0108! Display
low contrast and high contrast
- (441.83 KiB) Downloaded 564 times
- (454.55 KiB) Downloaded 564 times
Re: KS0108! Display
Hi Ressi!
Thanks for reply. Ok I see that you use the - 10V to the contrast, I have used the 5V pin. I Will try to change it later today.
You hear.
Br. Jorgen
You hear.
Br. Jorgen
Re: KS0108! Display SOLVED!
Hi Ressi!
The problem was the contrast. I have used 5V and ground instead of -10V and ground as supply to potentiometer.
Thank´s for help-
Br Jorgen
Thank´s for help-
Br Jorgen
