PIC16F18426 no output PWM
seokgi
Has thanked: 18 times
Been thanked: 16 times
Post by seokgi »
Hi.
I need help/.
16F18426 digital output is good but PWM output is not.
I do not know what I did wrong. The 18F26K80 works well with the same program.
  Help me Please.
16F18426.fcfx
(10.68 KiB) Downloaded 220 times
celebriums
Has thanked: 71 times
Been thanked: 33 times
Re: PIC16F18426 no output PWM
Post by celebriums »
Hi seokgi
I think Flowcode 7 and 8 does not support the PIC16F18426 processor.
Which version of Flowcode do you use?
Sincerely Regards
Sadık SUME
www.kaandesign.com.tr
seokgi
Post by seokgi »
Thanks for the reply.
I knew that 16F18426 does not support FC7 or FC8. So I contacted MatrixTSL and got the chip support file for FC8. If you try update, you will know.
On other PICs, PWM is good on FC7 or FC8. However, when the same program is run on the PIC16F18426, the output value does not appear. Perhaps the chip support program may be a problem, but it may be my fault that I am not good enough.
Thank you for your attention.
I've pushed a change to the update system now which should hopefully solve the problem for you. Update your files and restart Flowcode to ensure you are running the latest files before you compile to chip.
https://www.matrixtsl.com/wiki/index.ph ... ic_Updates
Let us know how you get on.
