(Solved) Atmega16_MCP4922 problem
maharadga
Has thanked: 17 times
Been thanked: 12 times
Post by maharadga »
I have problem with SPI. Maybe mistake is my, maybe it's a bug.
I want produced DAC volt and DAC current with MCP4922. It's a 2 channel SPI DAC from Microchip.
But I found something strange.
Vol toutput is 2,5V and Current output is 0V with dac_Volt and dac_Current = 0.
With dac_Current I can adjust only Volt Output.
If I decrease dac_Current by one, output Volt is jump to 5V. If increase dac_Current, output is increase too.
With dac_Volt can't adjust anything.
I connect PIC MOSI with MOSI on MCP4922. Otherwise I lost comunication. And should not I connect MISO with MOSI and vice versa? Same problem with connection exist and with MCP3202.
This is real design.
I post Flowcode project, datasheet MCP4922 and Proteus project.
MCP4922.pdf
(3.62 MiB) Downloaded 231 times
Proteus_Atmega16_MCP4922.rar
(17.49 KiB) Downloaded 268 times
Atmega_16_MCP4922.fcfx
(22.67 KiB) Downloaded 250 times
Re: Atmega16_MCP4922 problem
MOSI should go to MOSI and MISO should go to MISO.
MOSI = Master Out (SDO) Slave In (SDI)
MISO = Master In (SDI) Slave Out (SDO)
So the cross connection is done for you using the MOSI / MISO naming convention.
Looks like you are very close to a solution. This line of code may be the problem.
send_Volt = dac_Volt | 0x7 << 12
Try adding brackets to ensure the maths is correct.
send_Volt = dac_Volt | (0x7 << 12)
Same for the Current channel.
Let us know how you get on.
maharadga
Post by maharadga »
Hello, Benj.
I found out about the connections.
I add brackets, like you say, but result is the same.
Have you wired up the external Latch pin and Enable pin?
maharadga
Post by maharadga »
Yes, LDAC pin is connected to GND. Output registers are updated immediately.
maharadga
Post by maharadga »
I changed in Properties "Clock polarity" to Idle High and problem was resolved.
This work in real chip.
Have a nice day.
(20.34 KiB) Downloaded 270 times
