Trialing Flowcode 8 programmer problem
iain wilkie
Has thanked: 13 times
Been thanked: 9 times
Post by iain wilkie »
I am thinking of upgrading from V4 to V8 so playing around with the free 30 day trial version.
I am using the AVRISP mkII programmer and when running V4 all is good.
However it fails to recognise the chip when running V8 (see picture below)
Any help appreciated !!!!
Iain
programmer problem.jpg (26.81 KiB) Viewed 4919 times
Re: Trialing Flowcode 8 programmer problem
Looks like you will need to edit the default programming parameters to use the AVRISP mkII. We currently default to the AVR TinyUSB.
Simply click on Build -> Compiler Options.
Select the Programmer tab.
Click the save icon and give the new configuration a name, e.g. AVRISP
Ensure you have the new configuration highlighted and ticked as set to default.
Then change the programmer path and parameters as shown here.
https://www.matrixtsl.com/wiki/index.ph ... VRISP_mkII
Let us know how you get on.
iain wilkie
Hi Benj,
Did that but now it doesn't seem to find the programmer on the USB !!!
Programmer is plugged in and does enumerate ..... also still works fine in the V4 Flowcode.
Any more ideas ???
Snapshot of error attached
Iain
Programmer problem 2.jpg (72.71 KiB) Viewed 4889 times
It could be a driver issue, I believe Flowcode 4 worked with an earlier version of the AVRISP mkII USB driver.
There is a newer signed driver available from the "Flowcode 8\Drivers\AVRISPmkII" folder which hopefully should work fine with v8 and also not break the v4 installation.
iain wilkie
Hi Benj,
Ok updating the driver worked for V8 but doesn't work on my V4 !!!
This is causing me problems as to upgrade to V8 I need my V4 programs to work under V8 and they don't and I'm not entirely
sure why. I *think* it might have something to do with the PORT i/o writing or TMR0 interrupt ... has there maybe been some changes there ?
Also I note in V8 there is no "View ASM" ????
Iain
Hello Iain,
Glad v8 is now able to program, rolling back the device driver will allow v4 to work again. The USB driver for the AVRISP is very messy and I'm very glad we have now moved away from it as our go to AVR programmer. The USB tiny has no driver issues :D
Regarding updating projects from v4 to v8. This is a big jump in terms of components and devices etc and so the fact there are some problems is probably not that unexpected. I would check things like component properties and interrupt icon properties. If these are all ok then hopefully the programs will work as expected.
iain wilkie
Hi Benj,
The problem I seem to have is with TIMR0 overflow interrupt (on a ATTiny13) It works fine downloading to chip in V4 but not downloading from V8
It seems the interrupt screws things .... could it be too long in V8 ??? not sure.
I note there is no "View ASM" in V8 ????? this would help me find out what could be wrong ......
Iain
Hello Iain,
You can still view the assembler code by opening the .asm file in your project folder with a text editor.
Maybe check the timer interrupt enable icon's properties are setup as you are expecting, they likely will have reverted back to default.
These statements seem to contradict each other. Please could you clarify.
iain wilkie
What I mean is the programmer now works on V8 but not on V4 ... I have to revert back to the old driver to work on V4
What I mean is the program runs good if programmed from the V4 flowcode, but doesn't run when programmed from the V8 flowcode
but this seems to be something to do with the timer0 interrupt
Iain
iain wilkie
Benj,
There is no .asm file produced !! ... only a .lst file
Iain
