I need to initialize very large array, up to 2048 value.
The data are in this format
ARRAY [] =
0x00, 0x00, 0x00, 0x00, 0x00,
0xFE, 0xE0, 0x00, 0x00, 0x00
0xFF, 0x5C, 0x00, 0x00, 0x00,
0xFF, 0xF5, 0x08, 0x20, 0x00,
0xFF, 0x38, 0x00, 0x00, 0x00,
0xFF, 0x80, 0x00, 0x00, 0x00,
I initialized the array with the C code using this instruction
array [430] = {0x00, 0xFF ....};
but without success.
The compilation does not report errors, but the array is not initialized
any suggestions?
Thanks in advance
How to initialize large Array
- Has thanked: 553 times
- Been thanked: 1081 times
Re: How to initialize large Array
What is your target device? The Lookup component is probably what you are looking for.
― C.S. Lewis
― C.S. Lewis
Hi Kersing
my target devide is dsp, specifically the ram.
I need to perform several configuration writes, but for the two larger ones, which are the program and the parameters I need two different arrays.
By checking the forum I saw that they were postponed for the lookuptable but I can not figure out how to make it work.
Data from these arrays must be transmitted via i2c.
I have already tried to communicate a single byte with the dsp and it works correctly, as I have tested the sending of a small array and that has worked too.
How do I pass the values of this lookup table to the i2c macro?
For target device I mean which controller do you want to use? PIC 8 bit, PIC 16 bit, ARM, Atmel?
― C.S. Lewis
― C.S. Lewis
Hello everyone
I update you about the initialization of a large array.
I was able , through the use a lookup table, to initialize an array and to program the external memory!
