PIC16FV32K303
DirkB
Has thanked: 7 times
Been thanked: 11 times
PIC16FV32K303
Post by DirkB »
Is it correct that the chip PIC24FV32K302 has no port interrupt
falling Edge, only both, rising and falling edge ?
thanks
Dirk
Re: PIC16FV32K303
Hi Dirk,
Yes it looks that way looking at the datasheet. You can do rising or falling detection in software by monitoring the pin states.
DirkB
Re: PIC16FV32K303
Post by DirkB »
found it. This chip has 3 pins set for this task. This pins are Int0 pin 16,
Int1 pin 25 and Int2 pin 20 (24Fxx) or pin 23 (24FVxx).
Dirk
Has thanked: 182 times
Been thanked: 179 times
Re: PIC16FV32K303
Hi Dirk, Hi Ben
I have a problem in my hardware with a interrupt and a Pic32MZ2048ecg and Pic32MZ2048efg
as similar as here is the question.
I had a look in the datasheet from the PIC24FV32
and it look as the PIC has Edge Detect Polarity.
Also my PIC's have this bit.
But how can we use that with FC8 ? Maybe just change a bit in a register?
bit 2 INT2EP: External Interrupt 2 Edge Detect Polarity Select bit
1 = Interrupt is on the negative edge
0 = Interrupt is on the positive edge
bit 1 INT1EP: External Interrupt 1 Edge Detect Polarity Select bit
bit 0 INT0EP: External Interrupt 0 Edge Detect Polarity Select bit
http://ww1.microchip.com/downloads/en/D ... 09995e.pdf
DirkB
Re: PIC16FV32K303
Post by DirkB »
Hi Stefan (Stefan deutsch? ;o),
use the INT Icon in Flowchart, double klick on it and you will see.
Dirk
Re: PIC16FV32K303
Hi Dirk
(Ja, wir sprechen deutsch in der Schweiz)
Your Pic looks good for the INT, only my Pic is a litle different.
For you it's clear how to use INT with B7,B14,B12 but the PIC32MZ2048EFG100
is not clear how to use, because four out of five external interrupts are remappable.
The Int0, I found is on Pin71 on D0
Do you have an idea how to use the anothers?
I need one interrupt on C3....
Re: PIC16FV32K303
Hi Dirk, Hi Ben
It looks as if I need INT2 for Pin C3
(59.64 KiB) Downloaded 1980 times
Re: PIC32MZ2048EFG100 Remap INT
Hello Stefan,
If you go into the interrupt properties then it should allow you to assign the remap pin.
Do you need the interrupt to simulate? Currently the simulation pin is fixed but the downloaded pin can be remapped.
Re: PIC16FV32K303
Perfect.
A little my mistake. I only looked at the INT0 and this is fixed and not remappel
In the Int2 is a nice menue for choosing the pins. I like the FC8...
(19.44 KiB) Downloaded 1976 times
Re: PIC16FV32K303
I have changed my program to the INT2 on PIN C3.
The result is not ok. If I check the signal on PIN3 there is always a low signal.
When I change it back to Interrupt on port C and choose C3 then signal on PIN C3 is toggeling.
As if the configuration from INT2 on Pin C3 set the input always to low....
This is on the PIC32MZ2048ECG100
Did I do something wrong?
Re: PIC16FV32K303
Hi Stefan,
Please can you post your program so we can have a look for you.
Re: PIC16FV32K303
So I changed my program a little. If I select the Portc and PIN C3, my program is running.
If I select the INT2 on PIN C3 it's not working.
For both Interruppt, I checked the signal on Pin C3 (input) with the osciloscope and there is always a signal toggeling to flash thr INT .....
To select the INT on one place
(17.15 KiB) Downloaded 1940 times
To show the flashing INT I turn on and off a green LED
(84.06 KiB) Downloaded 1940 times
Fc8_ecg100_emg_ekg_icd4_v1.fcfx
(415.17 KiB) Downloaded 221 times
Re: PIC16FV32K303
How is the litle Interrupt problem with PIC32MZ2048EFG100 ?
For my project " Low-Noise, 6-Channel, 24-Bit Analog-to-Digital Converter for Biopotential Measurements "
(reading ADS1299 chip) it's a big help if the Interrupt is working fine.
