18F25K22 compiler error
Lord Grezington
Flowcode V4 User
Has thanked: 29 times
Been thanked: 30 times
Post by Lord Grezington »
Hi all
Got some problems tryingto compile anything...
Below are the compiler messages, and I have also added the compiler settings
35: __config("__PROG_CONFIG", "pic18", 0x4, 0xFF);
^ (1504) the PIC18 extended instruction set was enabled but is not supported by this compiler
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
FINISHED
compiler messages.jpg (43.07 KiB) Viewed 2246 times
Re: 18F25K22 compiler error
Lord Grezington wrote:(1504) the PIC18 extended instruction set was enabled but is not supported by this compiler
Go into the configuration settings and disable extended instruction set.
