Pic32MZ2048EFG100 UART is 4 times to slow
Has thanked: 182 times
Been thanked: 179 times
Have a problem with the Pic32MZ2048EFG100 and the UART.
The speed from the hardware UART is about 4 times to slow. The clock is ok with 200Mhz because the delay from 1mSec is perfect.
How can I acces the PB2DIV from the PIC?
(98.59 KiB) Downloaded 1825 times
Re: Pic32MZ2048EFG100 UART is 4 times to slow
On the PIC32 devices there is a peripheral clock as well as the main oscillator clock. Can you post your program so we can see what the various configuration settings are set to.
Here the program
Fc8_efg100_emg_ekg_prototype_v15.fcfx
(448.3 KiB) Downloaded 262 times
I found some infos about it.
And I tried it.
But the Baudrate (speed) did not change.But I dont have a error. Maybe I did something forget?
  Enter C code below this comment
//Unlock Combination
_SFR_WRITE(&SYSKEY, 0xAA996655);
_SFR_WRITE(&SYSKEY, 0x556699AA);
//Unlock
_SFR_BIT_SET(&PB3DIV, 11);
//_SFR_BIT_SET(&PB3DIV, 1);
_SFR_BIT_CLEAR(&PB3DIV, 1);
// now lock again PB3DIC
_SFR_BIT_CLEAR(&PB3DIV, 11);
// now lock again
_SFR_WRITE(&SYSKEY, 0x0);
http://ww1.microchip.com/downloads/en/D ... 01250B.pdf
In a old post I found about the divider on an another PIC32(MX).
This I FPBDIV I cannot find for the PIC32MZ2048EFG100
Also a little special…. The Baudrate on the ECG PIC was ok..
http://wwww.matrixmultimedia.com/mmforu ... ilit=PIC32
There is a little problem to fix the speed from the Uart and SPI.
I suspect that this setting is missing for the clock in FC8 and PIC32MZ2048EFG100.
When I try to change this while the PIC is running,
the PIC need 60 steps to change it. How can I program it?
Hi Stefan,
You should be able to use a delay icon to do the task of waiting at least 60 CPU clocks. I would guess that say a 1ms delay would be plenty.
I like to show first the value from the register on the display of the board.
As if its working not correct.
So I tried to test with the watchdog settings
It shows me values, but if I show DEVCFG1 and change the value from the watchdog WDTPS in the project-option-config.
it shows me always the same value…..
But the value in the C-code changed
#pragma config WDTPS = 14 to ]#pragma config WDTPS = 6
//show  register on display
//_SFR_BIT_SET(&PB3DIV, 4);
FCI_DELAYBYTE_MS(1);
//FCV_REGDISPLAY  = &PB3DIV;	      //Copy to variable
//FCV_REGDISPLAY  = &DEVCFG2;
FCV_REGDISPLAY  = &DEVCFG1;
FCD_08221_LCD_SSD1351__ClearDisplay();
FCD_08221_LCD_SSD1351__PrintNumber(FCV_REGDISPLAY, 50, 50, 0, 0);
To set the clock divider is working but it's not the problem.
I think it's more on the UART config. It looks like the BRGH is wrong (I or 0) I will check it tomorrow….
here the code to set PB2DIV
//_SFR_BIT_SET(&PB2DIV, 1);
//_SFR_BIT_SET(&PB2DIV, 4);
FCV_REGDISPLAY  = PB2DIV;
// now lock again
Lagoda
Has thanked: 69 times
Been thanked: 61 times
Post by Lagoda »
Hi Stefan and Ben,
I have the same problem with the PIC32MZ EFM.
My target board is Microchip Curiosity.
I attached a little test program what I used for the check.
Best Regards,
Lagoda
PIC32MZ_TimingsChecking.fcfx
(10.33 KiB) Downloaded 225 times
Hi Lagoda, Hi Ben
The BRGH bit is correct. It's 1. But the value for the Baudrate-generator BRG is (maybe) wrong
I attached an excel table with the old and new value. I take a measurement with my Osciloscope and it's shows 8.69 uSec for one bit. And the terminalprogram is working with 115200 Bd.
// For uart Nr 4  115200 Baud C Code
U4BRG=216;
Baudrate.xlsx
(8.62 KiB) Downloaded 202 times
ronaldlijs
Has thanked: 20 times
Been thanked: 25 times
Post by ronaldlijs »
Hi Ben et al,
Just to say that I obviously have run into this problem as well. We have not tried Software UART option (in case this works for some reason) as we need the RXINT though.
Our MCU FYI is PIC32MZ1024EFE100
The only solution at the moment is to modify the Flowcode settings to match the real life. Simply multiply by 4x the baud rate used, set the Baud Options to Custom and enter the new number into the Baud Rate field for the UART Component in Flowcode 8.
SO TO MAKE IT CLEAR FOR OTHER PEOPLE RUNNING INTO THIS PROBLEM...
Say you use baud rate 57600 (our case). Simply multiply this number by 4x which equals 230400. And enter this new number in the Flowcode properties window as below. The clocked UART output stream runs exactly at 57600bps :D
Hope this helps, regards!
R
