RPI modbus TCP
Re: RPI modbus TCP
The good news is as you say, the flowcode master>slave example does seem to work now. Unfortunatly when using external modbus masters, i ether got no response, or an incorrect reponse. Did you test a 3rd party master or just a flowcode master?
I think my next step is to use wireshark to look at the tcp packets and try and see where its going wrong, but wanted to let you know it doent look good in the mean time.
Ill keep you posted.
Best Regards
James
Best Regards
James
Re: RPI modbus TCP
Having looked into this some more, this does seem to work in simulation. However when using an external master to query the program, I ether get a incorrect response (analogue or binary) , or a failed transaction, depending on the modbus master program I try.
To try an pin this down, I used wire shark to capture the TCP packets between master and slave.
First I tried a read holding register transaction between a master and a known working slave device (not flowcode). You can see the request go out, and the response from the device.
I then tried exactly the same transaction with the flowcode modbus slave example. You can see again the request get sent, but no response packet is ever sent from the slave.
I believe this explains why writing values works, as no response is required, however most masters require one to flag a successful write. Consequently the values are written, but some master devices will show a failed transaction.
When trying to read a register or coil however the slave needs to send a response, as shown in the successful transaction above. The flowcode program is clearly not doing this. I am however at a loss to explain how the flowcode>flowcode simulation example is working!
If we are to use modbus tcp for reading values from a flowcode based device, it needs to send the proper responses to read or write quires via TCP. At the moment, it certainly does not seem to be doing this?
Would it be possible for you to take a look and see why this might be?
Best Regards,
James
Best Regards,
James
Re: RPI modbus TCP
Hi James,
Many thanks for your time and effort here. The Modbus TCP components have only been tested together and not with other third party equipment. The None TCP Modbus components have been tested with third party equipment though and is known to work. The code bases for the modbus part should be identical.
So it's probably something to do with the opening and closing of the TCP port. I'll have a look for you and see if I can get any further to solve the issue for you. In the mean time if you find anything further then please let me know as it may be of great help.
Re: RPI modbus TCP
HI Ben,
I agree, the non TCP Modbus components work very well in my experience, so I don’t think the problem is there. It certainly seems to be that the tcp port is being opened and closed without issue. I have tried to capture an entire tcp exchange of a good Modbus transaction with a known good device, and also with the flowcode component. As you can see below, it’s not that the component doesn’t respond. The only difference I can see is that the component doesn’t send the modbus "response" packet in reply to the query, otherwise everything else looks good. Maybe there is something in the tcp comms component that is stopping the packet being sent?
Best Regards
James
Best Regards
James
- (124.15 KiB) Downloaded 1983 times
- (76.24 KiB) Downloaded 1984 times
Re: RPI modbus TCP
Hi James,
Having another look for you now using the QModMaster Modbus Master software.
It connects but I can't currently get it to transfer any data to the Flowcode simulated Modbus TCP Slave.
I'll see if I can work out what's not working.
Re: RPI modbus TCP
HI Ben,
Thats great, thankyou. Yes the QmodMAster needs to see the reponse packet even when writing, so it shows fail when writing as well as reading. That replicates exactly what i see. Please let me know if i can help in any way.
Best Regards
James.
Best Regards
James.
Re: RPI modbus TCP
Hi James,
I've been working on this and have got it at least partially working now. I'll spend a bit more time and do a push later today so you can try my improvements.
Re: RPI modbus TCP
Thats great, thank you. I just checked and there doenst seem to be any update to the modbus slave component but let me know when ts ready and I Iwill give it a try.
Best Regards,
James.
Best Regards,
James.
