dsPIC33EP512GM304 OSC PLL setting help me!!
seokgi
Has thanked: 18 times
Been thanked: 16 times
Post by seokgi »
Hi.
I'm using a 16-bit processor for the first time in this project and I use dsPIC33EP512GM304. It's very different from 8 bits. I've compiled and downloaded it, but I have to use the UART, which is very difficult to set up OSC PLLs, etc. Can anyone help me?
Thank you.
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: dsPIC33EP512GM304 OSC PLL setting help me!!
Post by QMESAR »
Yea the dsPIC33 is great micro.
Well you have to give some info to help you
(1) what OSC are you using Internal /External if external what is the frequency of the Chrystal
(2) what Clock speed you would like to use
QMESAR
Post by QMESAR »
Here is the config for using and 8Mhz Chrystal and running at 70Mips(140 Mhz)
* Configure device for 70 Mips with 8 MHZ XTAL
PLLFBD = 68;              /* M=70 (68 +2)*/
CLKDIVbits.PLLPOST = 0;   /* N1=2 */
CLKDIVbits.PLLPRE = 0;    /* N2=2 */
OSCTUN = 0;         //Tune FRC oscillator, if FRC is used
//Disable Watch Dog Timer
RCONbits.SWDTEN = 0;
// Clock switching to incorporate PLL
__builtin_write_OSCCONH(0x03);   // Initiate Clock Switch to Primary
__builtin_write_OSCCONL(0x01);
while (OSCCONbits.COSC != 0x3);
//ensure PLL lock before moving on into application code
while(OSCCONbits.LOCK != 1);	/* Wait for Pll to Lock */
use a C icon enter the c code and place the C icon before the main loop so that it is execute on start up only
here are the settings for Project option
seokgi
Post by seokgi »
Thank you very much.
But I want to use internal clock, so let's study with advice. Thank you for your attention.
QMESAR
Post by QMESAR »
HI
Yes I understand now that you want to use internal OSC then you have to say so when you ask for help .
any case the principal of setting it up is the same
seokgi
Post by seokgi »
Thank you QMESAR.
I will try it. and study it.
