Page 5 of 5
Re: MIAC based temperature controller
Posted: Thu Dec 20, 2012 12:45 pm
by DylanBalloo
Hey Leigh, still cant find the nldx in pwm....does it works as in flowcode 4
Posted: Thu Dec 20, 2012 12:57 pm
by DylanBalloo
I've tried a to run a small program using pwm, when running the simulation its working but when uploading it on miac,there's error??
Posted: Thu Dec 20, 2012 1:27 pm
by LeighM
Hi Dylan
Your program looks good. Only one small thing missing: You need to go to the “Connections” and select “MIAC(0)” for each PWM component.
(You need this extra step because your project setting is “MIAC System” rather than “MIAC”, so with MIAC System the PWM component could be attached to an Expansion module)
Leigh
Posted: Thu Dec 20, 2012 3:50 pm
by DylanBalloo
Ok,working...thanks Leigh...
Posted: Sun Jan 27, 2013 7:33 pm
by DylanBalloo
Hello friend,
Do you have a written program for MIAC and the GSM module. I want to send an sms from the GSM module to a phone number.How can I do it??..
Thank you
Posted: Mon Jan 28, 2013 10:10 am
by LeighM
You can send a text message by using the three macros of the GSM component:
Initialize
CheckNetworkStatus
SendTextMessage
First call the Initialize macro,
then loop, including a 1 second delay, waiting for the CheckNetworkStatus macro to return a value of 1 to indicate that the network has connected.
Then use the SendTextMessage macro to send the required message.
Leigh
Posted: Mon Jan 28, 2013 5:33 pm
by DylanBalloo
Ok thank you Leigh...
Posted: Mon Jan 28, 2013 5:39 pm
by DylanBalloo
Can I ask you something is is possible to send a message to the GSM module to activate any relay or motor output??
Posted: Tue Jan 29, 2013 10:01 am
by LeighM
Hi Dylan
Yes you can use the CheckForIncoming macro to detect that a text message has been received.
Then use the ReadString macro and check for a particular text string (such as ON and OFF) and switch an output accordingly.
Have a look at the GSM component help file for further information.
Leigh
Posted: Tue Jan 29, 2013 12:19 pm
by DylanBalloo
Where can I get the GSM help file??
Posted: Tue Jan 29, 2013 12:27 pm
by LeighM
Hi Dylan
The help can be invoked from within Flowcode.
In the Properties panel, select the GSM Component and you will see Ext Properties, Connections, Custom Code and Help
Leigh
Posted: Tue Jan 29, 2013 2:25 pm
by DylanBalloo
Ok thank you Leigh.
