PB with MACRO on Flowcode 5 AVR pro
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: PB with MACRO on Flowcode 5 AVR pro
Post by DavidA »
Hello Yann,
I have given this to someone else with an ATMEGA128 and he has reported that all the programs linked in this thread have worked perfectly for him.
His boards are 16Mhz boards and his fuse settings are:
0x0, 0xdf (low)
0x1, 0xff (high)
0x2, 0xff (extended)
Can you reply with your fuse settings and clock speeds.
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
Hmmm, that's true. No idea why you have that problem.
Could it be hardware related ? Fuses maybe ?
EDIT : Didn't see David's post, my bad
yann.cosson
Has thanked: 5 times
Post by yann.cosson »
on AVR studio Prog page i have :
see the 2 pics,
LOW : 0xC4
HIGHT : 0x99
EXTENDED : 0xFD
first pics
(36.6 KiB) Downloaded 6853 times
yann.cosson
second pics
(4.16 KiB) Downloaded 6853 times
yann.cosson
poufffffff
i put the low, hight and extended fuses with the value you done to me, and now i can't connect with my jtag to my card, i have an error.
The avr prog doesn't recognize my µC.
it's look like i have kill my µC...
:cry:
So i couldn't test the flow you send.
:cry:
Yann.
yann.cosson
My JTAG is no more able to read device information, i have a message error :
Timestamp: 2012-08-01 21:31:45.875
Severity: INFO
ComponentId: 20100
StatusCode: 0
I can read, and i could not prog anymore too. :cry:
What can i do to go back to my value ?
yann.cosson
Little add,
When i connect my JTAG ICE MKII on my card, the ARV STUDIO couldn't read the signature of the chip.
i have a 0x00, 0x00, 0x00 signature.
i change the µC this morning, and i think i will never play again with the fuses :(
Yann.
yann.cosson
I changed my µC and i put a new one on my card.
bye bye the other one :cry:
i read the fuse factory setup before doing anything else
(67.07 KiB) Downloaded 1996 times
yann.cosson
i just changed SUT_CKSEL with internal 8MHz
i flash a k2000 and my card is ok now :D
i tried the last flow you send me with 3 macro, it works on Flowcode, but when i want to flash it in my card i have an error.
when i flash one of my flowcode it's ok.
What is the different between mine and yours ?
What can i do to make flowcode v5 avr macro works ?
Why the same flow, with the default setting of flowcode, works on v4, and doesn't on v5 ?
i bought Flowcode, because i thought that what i simu is what i get, but for the moment it doesn't.
Is there a special configuration to make it work ?
Do have i to buy Matrix E-blocks card to make it work ?
Yann, :D
Spanish_dude
yann.cosson wrote:i tried the last flow you send me with 3 macro, it works on Flowcode, but when i want to flash it in my card i have an error.
What error do you get ?
yann.cosson
i have a ATMEL STUDIO prog error.
a ATMEL STUDIO popup appears, saying that he was unable to prog because he couldn't find a valid file .hex,
But in the directory i have the file generated by flowcode.
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
Hi yann
Can you post a screenshot showing the error as it will enable others to get a better idea of whats wrong
Dazz
DavidA
Post by DavidA »
Hello Yann,
The fuse settings i posted were the standard recommended values for use with the AVRISP programmer. I did not intend for you to change them to that! I just wanted to check your values to ensure that the watchdog and brownout features were configured appropriately - to try to stop the chip from resetting.
These standard AVRISP fuse settings also disable the JTAG interface - to free up the associated I/O pins.
You seem to be using a JTAG programmer so this action has locked you out. The JTAG option can be re-enabled via the ISP interface if a compatible programmer is available. It is not possible for an ISP programmer to disable the ISP interface, but it looks like it is possible to disable JTAG via JTAG.
We try our best to ensure that the Flowcode simulation is as accurate as possible, obviously this depends largely on the hardware used and that the settings that are in Flowcode are correct to ensure accurate simulation of hardware.
There may be specific fuse settings which you need to get it working, Clock source and programmer interface settings seem to be the two areas that can cause problems.
No not at all.
yann.cosson
when i try this, build on v4
FlasherTest_v4.fcf_avr
(6 KiB) Downloaded 286 times
yann.cosson
the result is :
(50.32 KiB) Downloaded 6825 times
yann.cosson
and
(54.58 KiB) Downloaded 6825 times
yann.cosson
when i put a flow i have done and that works on v4, all is OK on my card
(77.27 KiB) Downloaded 1981 times
yann.cosson
i made another thing i read the fuse of my ATmega328P where the macro on v5 works
(68.62 KiB) Downloaded 1980 times
yann.cosson
and i do the same on ATmega128 where MACRO doesn't work on v5
(85.04 KiB) Downloaded 1980 times
dazz
Post by dazz »
Hi yann
Dont throw out the avr with the locked fuses, heres a link to a probe that injects a voltage during programing to allow you to reset the fuse http://www.elektor.com/magazines/2011/j ... 2608.lynkx
theres also a lot of opensource circuits on the web to asllow you to do the same
Dazz
yann.cosson
On ATmega128, where my flow doesn't work on v5, i have M103C and JTAGEN check, that are not on ATmega328 (but no jtag on ATmega328 only isp).
on ATmega328P where macro works i have "BOOTRST" check and the value size is different.
Can it be a reason why ...
Yann :D
dazz
Post by dazz »
Hi yann
read the attached pdf pages 8 to 10, it explains the use of the m103 fuse, from that pdf i would tick jtagen and untick m103( it a compatability mode which locks out some 128 features) let us know how you get on
doc2501.pdf
(121.11 KiB) Downloaded 304 times
dazz
