Flowcode Release Candidate 6.0.6
Rudi
Has thanked: 493 times
Been thanked: 187 times
Re: Flowcode Release Candidate 6.0.6
Post by Rudi »
I have tested in RS232 and First Time a little "Cosmetic" playing with me..
If i add a RS232 Compo the Scope will show automatic .
If i close the Scope or deactivate in View or make it Auto Hide and then make Change in Properties example Baudrate,
the Scope again allways popup...
Input: Switch_array_push and Switch_array_Slide
Can not set Custom Pins
Best wishes
Rudi
georgp
Has thanked: 8 times
Been thanked: 4 times
Post by georgp »
Hi I updated the latest patch and several components stopped working. Visi for instance shows only a blank screen when I try to use it.
Hi georgp,
When Flowcode is upgraded, you need to reactivate it.
You can do that via help, Activate.
or see Here
georgp
Post by georgp »
No it is still not working the Visiwriteobject is blank. Hardware is working have to go back again to a previous version.
SteveM
Has thanked: 28 times
Been thanked: 65 times
Post by SteveM »
Rudi wrote:Input: Switch_array_push and Switch_array_Slide
Hi Rudy,
Good spot - thanks for your report.
In this case, it is the tooltips which are incorrect. We found that teachers were reporting that the old switch array was confusing for their younger students due to the many options, and they preferred "ready to use" components, complete with realistic switches. So, we created the 'Switch Array (Slider)', and 'Switch Array (Push)' as simple "drag and drop" components for observing a single port.
However, the more versatile version with individual pin assignments is still present, and can be found using the component search feature as the "Switch Array Base". (It is a "base" because the 'simpler' arrays are built upon it and inherit its core features).
(8.06 KiB) Downloaded 5461 times
Of course, we should make the tooltip text accurate so we don't confuse our users! - we'll make sure to change this before the next update.
Best Wishes
Steve.
Rudi
Post by Rudi »
Hi Rudy,
Hi Steve...
oh... ;-) ok... sorry - for this :-) .. then we have two spots ;-) ..
plz have a look to the pic.. in FC5 is possible to set each PIN in the Array... ( counts...each SW ..) in FC6 is not possible....( in the ready Sw Array )
If i want a SW Array.. i have allways insert example 4 single Switch and can then set each to PIN Select.....
...ah ....
This i have missed ;-)
i have not seen the "Sw Array Base"...
because ...in FC 5 does this possible in the past as a SW Array.. i do not spot the hint tooltext ;-)) i missed the function "each pin select " in the Aray..
so we have now 2 spots ;-)) ;-))))
ok thank you for your tip!
now is clear ;-)
i have found "Sw Array" and can select each Pins now..
Best wishes!!
Rudi
lordhex
Has thanked: 15 times
Been thanked: 10 times
Post by lordhex »
I Really want to ask you something.
in my pc i have 26 software i never ever use crack or anotherthings to use free.
I always give money to take a better service.And give an ardor to software writers.
after my short storry i am asking my question.
Why you always removeing items or components each patch?
How will i use 4x20 lcd in 6.0.7?Do i have to import?
or where is the beam breaker?
each software i use day by day growing with new options or components.
Exept flowcode...
I start flowcode 6.0.0.
And today we have 6.0.7 unfortunately...
I can't compare 6.0.0 with 6.0.7 becouse most of the components GONE...
Can you explain the reason of this?
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
All components are still there. The list was getting too large, so many are now hidden. Use the search function in the left of the component bar (i I recall correctly) to search for the component you need.
― C.S. Lewis
lordhex
Post by lordhex »
kersing wrote:All components are still there. The list was getting too large, so many are now hidden. Use the search function in the left of the component bar (i I recall correctly) to search for the component you need.
Do you know i really wondering why they are removeing components :D
I can't see them becouse i am blind :)
After youre explanation i feel really blind :)
Thank you for helping.
lordhex
Post by lordhex »
Well what is the problem now :(
And what can i do to resolve this problem?
with 16f84a gives problem
with 16f84 gives
and i tried 16f628 and gives no error.
Rudi
Post by Rudi »
can u pls check this:
PIC24FJ256GB106
I want to set INPUT sw to PORTB.12 - PORTB.15
example
PORTB SINGLE Bit at PORTB12..PORTB15
ist this PORTB_H 4 -7 ?
..in Entry Mask "Use Masing" the same..
Thank you!
Best wishes!
Rudi
To fix the EEPROM compile problem simply overwrite the 16F84A definition file with the file attached below. The location is "C:\Program Files (x86)\Flowcode 6\FCD\PIC"
16F84A.fcdx
(7.04 KiB) Downloaded 200 times
Yes the comparable connections are PortB_H 4 - 7
Also the prescaler is not correctly imported for a V5 flowchart.
This has now been fixed, It might not currently work for all devices as the data is now dynamic but the majority of 8-bit PICs and AVR should hopefully be ok.
This file also fixes the v5 servo component import to default to the servo controller component.
The file needs to be placed here: "C:\Program Files (x86)\Flowcode 6\plugins".
upgrade_data.xml
(172.61 KiB) Downloaded 306 times
Any issues let me know.
lordhex
Post by lordhex »
Benj wrote:Hello,
16F84A.fcdx
problem gone ty benj
georgp
Post by georgp »
Hi Guys
Any news on fixes for the latest release ?
We are are limping on a very buggie environment.
Seems that work done in 6.07 cannot be opened in previous 6.0.4 version.
I get some startup error
Re: RC5
medelec35 wrote:properties, for example receive mode, receive pin etc not being transferred from FC5
Unable to get RC5 to Work with 16F1937
Using attached flowchart.
This has now been resolved, was down to a line of C as part of the timer interrupt that had somehow been stripped out the component.
RC5.fcpx
(15.82 KiB) Downloaded 227 times
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Re: Flowcode Release Candidate 6.0.7
Post by hyperion007 »
I updated FC to 6.0.7 the other day and I wish I hadn't
Every time I click on any settings in the properties window for a component the "scope" pops up.
Every time I open a saved program file both "dash panels" are shown.
At least the chip config settings are actually saved now. but the rest is painful to work with. Sometimes when entering a return variable the text disappears then when I use the arrow keys the text appears again, flickering etc.
Will use FC5 until 6 is a bit more stable and not so buggy :(
Thanks for your comments,
This was deemed a feature and rolled out without really testing the functionality or the impact to the user, it bugs me too and so I think it will likely get ripped out or at least tamed down.
Flowcode should remember the state of the panels, however if this is not the case do you use the system panel at all? if not then you can disable it for good via the global options window.
Hmm this seems strange, in the Global options are you using OpenGL in hardware or software mode? Where is the text disappearing, is it in the macro dialogue window?
Any other pointers you can give us that we can investigate to help improve your usage of the product?
Work on the v6 application has currently stalled as our main C++ engineer Jonny has now left Matrix and the new engineer Martin is now away on holiday. As soon as he is back we will be able to proceed with bug fixes and stability improvements. One of Martins main tasks is to improve stability and to reduce the number of bugs. We know this is frustrating for users so please bear with us.
hyperion007
Hi Ben,
The text disappearing might have been a glitch on my end but a restart of both application and computer didn't help yesterday but now it seems to work. But the problem was in the Properties:Macro window and the text field Return Value. If I had a variable name entered already and clicked on the field, the text was gone.
I have hardware Open GL selected and I have now disabled the dash as I never use it (thanks for the tip). since the 6.0.4 to 6.0.7 update it no longer remembers the state of the panels, ever.
And I just meant that it was great that the chip config now gets saved but the scope, etc is rather painful.
Also I don't seem to get the GSM nor GPS components working, which I had working before the update. Will try it on FC5.
KevinH
Been thanked: 6 times
Post by KevinH »
I hoped to start learning Flowcode, so launched V6 (V6.0.3) and thought I'd check for any updates before starting and 'Help about' said 6.0.7 is available so I did a download and update.
Launching Flowcode after an apparently successful update it started.
The PIC24FJ128GC010 was not present so I thought I would just check again that my software was up todate and it says it is V6.0.3 and updates are available.
If I go to Help about also shows V6.0.3, I tried a second re-install with same result.
Checking in Control Panel Programs and Features I selected Flowcode 6 and ran a repair which I note states V6.0.1
After the repair Flowcode reports it is V6.0.3 as before.
I then ran the update again and clues to it may work were it took longer and the Flowcode 6 icon moved from where it had been (this had not occurred previously).
It now reports V6.0.7.0 as does 'Programs and Features' so all is OK.....
This is FYI and may help with other install issues.
Rudi
Post by Rudi »
how is this done?
i added a C icon and make a manually variable.
to work this in flowchart, i have make a second variable by variable manager
and give the value from variable 1.
in Simulation, the variable2 value will show.
after the c code, is the variable from variable manager again initialisied with Initial Value that i give it at Variable manager?
I have make a request for import function a variable list by file... in variable manager.
i have mean i can trick with this,, but do not go .
thank you!
best wishes.
Rudi
Rudi
Post by Rudi »
In Simulation this goes wrong.
I have make hex and upload to pic.
The Value of (1) is show fine in LCD.
So the Simulation goes wrong?
Best wishes!
Rudi
Edit:
Same like a Label text.
If you put a Label at panel and try to update the text, there is no updated text at panel in the label.
Hi Rudi,
Unfortunately Flowcode is unable to simulate C code, therefore variables will not be updated after a code box has been accessed.
If you wish to check code that contains C code prior to sending to your target device, then you will need to compile to hex, then use a third party simulator.
If you could post the flowchart (pm if you don't want it to be made public)) that is not updating text on the panel, I could take a look at it for you.
Marin
Rudi
Post by Rudi »
medelec35 wrote:Hi Rudi,
Marin
Hi Martin, thank you for fast help!
The third party simulator - is this in FC ?
I know Proteus 7 Prof that can simulate hex by corect shema in electronic, but this is for me to "ticky action" for fast simulate.
I work "at Work" with Proteus 7 Prof, but this only in hardware design and testing phase...
is there a way parallel to FC to test a hex? Do you know "third Party simulator" ?
can i buy this? where ? ;-)
the text on the panel for update, i will post next time my simple test flowchart.
i have test this parallel with the lcd output in simulation.
i can post it, this not secret ;-)...
TY!!!
Best wishes!
Rudi
Rudi
Post by Rudi »
Marin
Hi Martin,
simple example i append.
Best wishes
Rudi
