Using the ESP8266 examples
Has thanked: 187 times
Been thanked: 205 times
Re: Using the ESP8266 examples
Hi Rudi
Echo on or off makes no difference.
I can monitor both Tx and Rx on the ESP / uC so I can see what goes in and what comes out. Once the ClientConnect (for example) is issued, the Flowcode Macro itself is looking to see the ESP reply with "Linked".
If you look in the "C", you will find around line 1447 FCL_DONE = FCD_08181_WLAN_ESP8266__CheckForData("Linked", 7);
So unless the ESP sends "Linked" to the uC, then the program halts until timeout.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Could you try attached component where you are able to change the response to expect in the properties? (Set the responses your firmware provides in the items below ESP Responses)
WLAN_ESP8266.fcpx
(16.44 KiB) Downloaded 481 times
― C.S. Lewis
Hi Kersing
I will give it a try and let you know.
Many thanks.
Hi Kersing
I moved my original component to a different directory before downloading yours and restarting Flowcode.
However when I add in a new Component Macro and select ClientConnect I don't see any options in properties to select a response, just the same parameters as normal.
Am I doing something wrong?
kersing
Post by kersing »
The response strings are located in the component properties.
― C.S. Lewis
Hi Kersing
They are indeed, sorry for the confusion.
I am very pleased to say that I am able to change the expected response and the circuit ran without issue first time (and on a number of repeats too).
I set in component properties:-
ESP_CON_TO_SSID_CONFIRM = WIFI CONNECTED
ESP_CLIENT_CONNECTED = CONNECT
Many, many thanks for your help, it is very much appreciated.
MJU
Has thanked: 121 times
Been thanked: 108 times
Post by MJU »
I'm using the Matrix-Wiki ESP8266 TCP-Client example and I got it working with only one problem....
It seems to connect to the Matrix website and I can see on my logic analyser that the content of the test-file is being transferred.
But, the strange thing is that after issuing the request for the text file, I see the data appear on my logic analyser, but, the LCD doesn't get erased and the "Done" is shown on my LCD.
In my opinion, if the TCP request is send the LCD should always get erased??
Strange because the "Done" at the end appears and the "Connecting.." is still on the display.
