Flowcode V7
Re: Flowcode V7
There is a light and a dark theme. Most of the images we've produced use the dark theme because (in our opinion) it looks nicer. But the light theme has a better contrast and should be fine for those who don't like or find it difficult to work with the dark theme.
Alan_37
Has thanked: 51 times
Been thanked: 54 times
Re: Flowcode V7
Post by Alan_37 »
Hello Steve ,
Yes the Black theme is very nice, looks very PRO, any hints about the prices of Flowcode 7 ?
I don't know the prices but i was thinking that if it is worth it , would be nice if we can Pre order it now and take advantage of the Present GPB/Euro currency :)
Re: Flowcode V7
We've adopted a modular pricing structure for FC7, so you pay for the parts you want. We'll have a lot more information for you next Monday, and hopefully the exchange rates will have settled by then.
gtc
Has thanked: 30 times
Been thanked: 15 times
Re: Flowcode V7
Post by gtc »
Revamping look and feel is fine, as long as you have fixed the reported bugs in V6, especially those related to simulation.
Re: Flowcode V7
Is there anything in particular you would like to see relating to the simulation?
EtsDriver
Has thanked: 345 times
Been thanked: 227 times
Re: Flowcode V7
Post by EtsDriver »
How will lisencing scheme work on "on the field" programming machines/laptops, will we need internet access peridiocally to check valid licence or will the system be the old "activate once"?
Alan_37
Re: Flowcode V7
Post by Alan_37 »
Hi Steve
Is ti possible to add an Auto Save Option
Re: Flowcode V7
EtsDriver wrote:How will lisencing scheme work on "on the field" programming machines/laptops, will we need internet access peridiocally to check valid licence or will the system be the old "activate once"?
For paid-for licences, activation should only be required once. We are looking to implement a free 30-day trial, but this will likely require internet access for continued use.
Re: Flowcode V7
Alan_37 wrote:Is ti possible to add an Auto Save Option
Yes, this is something we hope to have.
gtc
Re: Flowcode V7
Post by gtc »
Steve wrote:Is there anything in particular you would like to see relating to the simulation?
Would like confirmation that the bug associated with breakpoints not being honored in simulation has been fixed.
It has been reported here: viewtopic.php?f=59&t=16688
... and should be on your bugs register -- if you guys maintain such a thing (I hope you do).
Re: Flowcode V7
gtc wrote:Would like confirmation that the bug associated with breakpoints not being honored in simulation has been fixed.
I've just checked and that was fixed in v6.1.3 of Flowcode. It also works fine in v7.
gtc wrote:... and should be on your bugs register -- if you guys maintain such a thing (I hope you do).
We use Jira.
gtc
Re: Flowcode V7
Post by gtc »
Steve wrote:I've just checked and that was fixed in v6.1.3 of Flowcode. It also works fine in v7.
Thanks!
Haven't fired up FC for a while so didn't realize that 6.1.3 was available.
Alan_37
Re: Flowcode V7
Post by Alan_37 »
Hi Steve
If i may suggest something i always wished in flowcode , sometimes when debugging with
simulation and you go step into 50 icons than an if statement and you forget to set the variable
of that if statement the simulation proceeds the wrong way and you have to stop and start again :?
I know this may not be something simple to implement but would really be nice if we have a step BACK in to icons
Re: Flowcode V7
Alan_37 wrote:I know this may not be something simple to implement but would really be nice if we have a step BACK in to icons
Thanks for the suggestion.
That does sound like an interesting improvement, but I can't think of a simple way of implementing it. It's obviously too late for V7, but I'll keep it on the list for consideration in future released.
Steve.
Rudi
Has thanked: 493 times
Been thanked: 187 times
Re: Flowcode V7
Post by Rudi »
Steve wrote: For paid-for licences, activation should only be required once.
fine
Steve wrote: We are looking to implement a free 30-day trial, but this will likely require internet access for continued use.
hi steve,
does FC7 have a Free Version like the FC5 free version with code limitation and so..
or is the limit for the free version then 30 days like FC6 and extra require internet access for continued use?
or is the require internet access for continued use then need, if user test more as 30 days and this is then the free version without limitation?
thanks
nice weekend!
@benj hear you away from desk a couple of week, so have nice holiday and come back asap intact and well again ;-)
best wishes
rudi ;-)
Re: Flowcode V7
Rudi wrote:does FC7 have a Free Version like the FC5 free version with code limitation and so..
The free version will be similar to V5 - there will be limitations on which chips can be used and how many icons/macros/components are available. We also hope to have a 30-day trial which will require internet access during the 30-day period.
Rudi
Re: Flowcode V7
Post by Rudi »
thanks, this helps a lot to organice here internet at offline places next week for the last option if you have a 30 day trial then.
only a simple question:
if FC7 is out, we can buy it then same time or do we must wait for a next time that is possible then to buy a "full professional version" ?
and if we can buy, we can do this key account same way in FC6 then? ( David ? ) ( append a FC7 key then in our FC6 account ?)
sorry for the detail question but i am next next week ( 11 july ) outside too couple of week and i would take all infos that i get outside too,
ps: and we can install it parallel to our FC6 version and FC7 do not change our FC6 install?
thanks!
best wishes
rudi ;-)
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: Flowcode V7
Post by dazz »
Hi Rudi
heres a post from steve a few days ago and should answer your last question
Dazz
Steve wrote:
stewartbaker wrote:Will the V7 Beta package be standalone ? That is to say can it be removed without affecting V6 ?
We probably won't be releasing the BETA to the public. However, V7 will have a functional free version which will be useful for small projects and for new users to evaluate the product. It is totally independent of Flowcode V6 and you can run both side-by-side without problems.
stewartbaker wrote:I want to check that long standing issues such as breakpoints have been finally fixed before committing anymore time or money to FC.
We're looking into that issue with ICD breakpoints at slower sim speeds and hope to resolve it for the release. Are there other issues you are particularly concerned about? I've reviewed your forum posts and I see we have resolved the other issues you have reported.
EtsDriver
Re: Flowcode V7
Post by EtsDriver »
Will the 64-bit architecture be supported with this new version? (To get all the juice out of our 64 bit rigs and all the RAM dedicated to the Flowcode... ;))
Re: Flowcode V7
EtsDriver wrote:Will the 64-bit architecture be supported with this new version? (To get all the juice out of our 64 bit rigs and all the RAM dedicated to the Flowcode... ;))
No - not yet. There are still parts of the codebase that need to remain as 32-bit for now. Sorry.
RobH
Has thanked: 29 times
Been thanked: 17 times
Re: Flowcode V7
Post by RobH »
Finally! Finally will have back the ability to compile PIC10F! We lost that sometime during v6, and I've groaned ever since with lost revenue...
Rudi
Re: Flowcode V7
Post by Rudi »
dazz
Re: Flowcode V7
Post by dazz »
Hi Rudi
were on GMT here give steve and the team a chance :), is your pc set to singapore time :lol:
Dazz
Rudi wrote:
Steve wrote:..We've adopted a modular pricing structure for FC7, so you pay for the parts you want. We'll have a lot more information for you next Monday, ...
The fanfare are available - where is the purchase and download link :mrgreen:
best wishes
rudi ;-)
Re: Flowcode V7
Rudi wrote:The fanfare are available - where is the purchase and download link :mrgreen:
http://www.matrixtsl.com/mmforums/viewt ... 54&t=17796
Alan_37
Re: Flowcode V7
Post by Alan_37 »
If we buy a Licence for Example without DSP , is it possible to later upgrade it to unlock the DSP function
with the same price of GPB 30 ?
