Page 2 of 2
Re: EB006 test program is the only programe that loads
Posted: Wed Jan 11, 2017 6:27 pm
by Steve
Hi Chloe,
The "slow mode" board is currently in production and will be ready when the course is released. As per my email, we will send one of these out to you with a 16F88 chip, along with the updated course.
The reason for not supporting the 16F1937 is that this chip's i/o works in a different way to the earlier chips like the 16F84a / 16F88 / 16F877a. Our assembly course is designed for beginners and so we felt it would cause too much confusion to support both the old and new chips. Once you have learnt the basics on a chip like the 16F88, it should be a lot simpler to transfer your knowledge to the 16F1937.
The 16F1937 can easily be removed and replaced with the 16F88 chip that we'll send you.
Steve.
Posted: Sat Jan 14, 2017 4:26 pm
Hi Chloe,
Just had a thought.
There is a command in assembly called
This allows you to call a
There is also a command called
That sensds the program back to next line down after the CALL.
So what you can do to make life a little easier before new add on board arrives is instead of multiple Delays of:
movlw 0x0
movwf DELAY;
Delay_0
DECFSZ DELAY, f
GOTO Delay_0
movlw 0x0
movwf DELAY
Delay_1
DECFSZ DELAY, f
GOTO Delay_1
etc..
You can just call the one delay as many times as you like.
For example :
; TUTA3.ASM 27SEP07
; Configuration data
; PICmicro MCU type: 16F1937
; Oscillator: Oscillator: XTAL mode
; LCD display: off
; 7-segment display: off
; Version 3 board settings: J14 links: Digital
; The following lines embed configuration data into the PICmicro
LIST P=16F1937
__CONFIG H'8007', H'FE4' ; Internal osc mode
__CONFIG H'8008', H'1EFF'
#DEFINE BANK0 MOVLB 0
#DEFINE BANK1 MOVLB 1
#DEFINE BANK2 MOVLB 2
DLY EQU H'20'
; using names to ease writing of TUTA2
PORTB EQU H'0D' ; name program location 13 as PORTB
LATB EQU H'10D'
ORG 0 ; Reset vector
GOTO 5 ; Goto start of program
ORG 4 ; Interrupt vector
ORG 5 ; Start of program memory
CLRF PORTB ; clear Port B data pins
BANK1 ; Page 1
MOVLW 0x07
MOVWF H'99' ; Setup the OSCCON register to set int osc at 31KHz
CLRF H'9E' ; Setup the ADCON1 register
CLRF PORTB ; set all Port B as output via Page 1
BANK2
LOOPIT BSF LATB,0 ; set Port B pin 0 to logic 1
CALL DELAY ;Goto the DELAY subroutine then when reaches a RETURN command goto next line down.
BSF LATB,1 ; set Port B pin 1 to logic 1
BSF LATB,2 ; set Port B pin 2 to logic 1
BSF LATB,3 ; set Port B pin 3 to logic 1
BSF LATB,4 ; set Port B pin 4 to logic 1
BSF LATB,5 ; set Port B pin 5 to logic 1
BSF LATB,6 ; set Port B pin 6 to logic 1
CALL DELAY ;Goto the DELAY subroutine then when reaches a RETURN command goto next line down. oto Delay_6
BSF LATB,7 ; set Port B pin 7 to logic 1
CLRF LATB ; clear all PORTB pins
GOTO LOOPIT ; goto address LOOPIT
DELAY ;Label Location address.
CLRF DLY
Delay_0
DECFSZ DLY, f
GOTO Delay_0
RETURN ;Return to the next line from CALL command
END ; final statement
It makes the code much shorter and easier to manage.
