dsPIC33EP128MC506, dsPIC33EP32MC502 and dsPIC33EP256MU806 CANBUS [solved]
An area to discuss 16-bit PIC specific problems and examples
celebriums
Has thanked: 71 times
Been thanked: 33 times
Re: dsPIC33EP128MC506, dsPIC33EP32MC502 and dsPIC33EP256MU806 CANBUS problem
Post by celebriums »
GetRxIdent 16 bit function is correct working. (Use Mask and Filter)
Problem 1 solved.
Thank you.
Problem 2: If I add a new variable, CANBUS can not read the line. (Example; byte8 = ABC)
Problem 3: If you add a new variable and send only data, it sends wrong value.
(0x12FE1240; buffer:0, DLC: 8,1,1,1,1,1,1,1,1 instead of 0x12FCBF41; Buffer8, DLC:4,1,1,1,1,1,1,1,1) as if it had shifted value.
Sincerely Regards
Sadık SUME
www.kaandesign.com.tr
Hello Sadik,
We're not too sure what you mean by this. Can you provide a simple example so we can better see what you mean.
celebriums
Hi Benj
I'il explain it now. After the GetRXIdent function works, I added a new variable from the left menu.
Variable>add new> Create a New Variable
Name of New variable: ABC
initial value: 0
Byte(number in the range: 0,255)
In this case, the GetRXIdent function does not work.
Sincerely Regards
Sadık SUME
Has thanked: 481 times
Been thanked: 699 times
Could you post a flowcode project with the variable added?
Reading back through your posts again, I think I see the issue, could you try the attached file please?
PIC16BIT_CAL_CAN.c
(68.8 KiB) Downloaded 409 times
celebriums
Re: dsPIC33EP128MC506, MC502 and dsPIC33EP256MU806 CANBUS problem (SOLVED)
Dear LeighM
Problem 2 and Problem 3 te seems to have solved the problem.
The update is working correctly.
Thank you very much for your help and support.
:D
Sincerely Regards
Sadık SUME
