Flowcode 6 & PicKit 2 [SOLVED]
Re: Flowcode 6 & PicKit 2
Hi John,
Have visited this thread?
JLeith
Has thanked: 146 times
Been thanked: 26 times
Post by JLeith »
Hello Martin
I think I found the missing part
I was looking around the forum and I found a issue with the Compiler.
In windows 10 you need to set Flowcode to Administrator. I did that and Flowcode worked.
My test bead not so much I must have something not right
More testing and I might be marking the investigation solved.
Martin I would not be where I'm at without your help.
(6.06 KiB) Downloaded 1390 times
JLeith
Post by JLeith »
(31.35 KiB) Downloaded 1381 times
Re: Flowcode 6 & PicKit 2 [SOLVED]
Hi John,
Your welcome.
Gald the issues have been solved.
I have changed the title to reflect this.
JLeith wrote:I was looking around the forum and I found a issue with the Compiler.
Yes, it shows you that in the last link I posted.
It also shows that you only may need to run in Administrator mode once, then maybe ok in normal mode after that.
