Page 2 of 2
Posted: Thu Nov 23, 2006 10:22 am
Hi Joe
Sorry I understand what you mean now.
In the Programmers Notepad (C For ARM Compiler)
Select Tools -> Options -> Tools
Then for the "build project" and "clean project" files you need to click edit and then click the "..." button next to Command.
Point both of the build and clean commands to your make.exe file or your makeARM.exe file normally found here.
C:\Program Files\Matrix Multimedia\WinARM\utils\bin
This should solve your compiling problems.
Posted: Thu Nov 23, 2006 8:57 pm
by joe
Benj wrote:Hi Joe
Yes i have found solution, please see my "protocol"
Great its running and compiling.
Systemeigenschaften/Umgebungsvariablen/Path = C:\Programme\Borland\BDS\3.0\Bin;C:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;C:\PROGRA~1\Borland\CBUILD~1\Bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\OrCAD\OrCAD_10.0_Demo\tools\specctra\bin;C:\OrCAD\OrCAD_10.0_Demo\tools\PSpice\Library;C:\OrCAD\OrCAD_10.0_Demo\tools\bin;C:\OrCAD\OrCAD_10.0_Demo\tools\fet\bin;C:\OrCAD\OrCAD_10.0_Demo\tools\Capture;c:\Programme\Java\;C:\Programme\Java\jdk1.5.0_09\bin\;C:\WINDOWS\system32\WindowsPowerShell\v1.0;C:\Programme\Matrix Multimedia\WinArm\bin;C:\Programme\Matrix Multimedia\WinArm\utils\bin;
System/Enivroment/
======= C for ARM configuration and error Msg:============================
Standard make.exe in >Tools>Options>Tools>(None - Global Tools) Build Project ->Edit
> "make.exe" all
MAKE Version 5.2 Copyright (c) 1987, 2000 Borland
Error makefile 13: Command syntax error
*** 1 errors during make ***
> Process Exit Code: 1
Rename make.exe to makeARM.exe
>Tools>Options>Tools>(None - Global Tools) Build Project ->Edit makeARM.exe as Command
Command: makeARM.exe
Folder: %d
Parameters: all
Shortcut: keine
Save: All Files
>Console I/O
Output Parsing: use the built-in error parser.
Message:
> "makeARM.exe" all
-------- begin --------
arm-elf-gcc (GCC) 4.0.1 (WinARM)
Copyright (C) 2005 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Assembling (ARM-only): ../Global/Cstartup.S
arm-elf-gcc -c -mcpu=arm7tdmi -I. -x assembler-with-cpp -DROM_RUN -Wa,-adhlns=../Global/Cstartup.lst,-gstabs ../Global/Cstartup.S -o ../Global/Cstartup.o
Compiling C (ARM-only): main.c
arm-elf-gcc -c -mcpu=arm7tdmi -I. -gstabs -DROM_RUN -O2 -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=main.lst -I../Global -MD -MP -MF .dep/main.o.d -Wnested-externs -std=gnu99 main.c -o main.o
Compiling C (ARM-only): ../Global/Cstartup_SAM7.c
arm-elf-gcc -c -mcpu=arm7tdmi -I. -gstabs -DROM_RUN -O2 -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=../Global/Cstartup_SAM7.lst -I../Global -MD -MP -MF .dep/Cstartup_SAM7.o.d -Wnested-externs -std=gnu99 ../Global/Cstartup_SAM7.c -o ../Global/Cstartup_SAM7.o
Linking: main.elf
arm-elf-gcc -mcpu=arm7tdmi -I. -gstabs -DROM_RUN -O2 -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=../Global/Cstartup.lst -I../Global -MD -MP -MF .dep/main.elf.d ../Global/Cstartup.o main.o ../Global/Cstartup_SAM7.o --output main.elf -nostartfiles -Wl,-Map=main.map,--cref -lc -lm -lc -lgcc -T../Global/AT91SAM7S64-ROM.ld
Creating load file for Flash: main.hex
arm-elf-objcopy -O ihex main.elf main.hex
Making .bin file
hex2bin v1.0.1, Copyright (C) 1999 Jacques Pelletier
Lowest address = 00000000
Highest address = 000002DF
Creating Extended Listing: main.lss
arm-elf-objdump -h -S -C main.elf > main.lss
Creating Symbol Table: main.sym
arm-elf-nm -n main.elf > main.sym
Size after:
main.elf :
section size addr
.text 736 1048576
.data 0 2097152
.bss 0 2097152
.int_data 0 2113536
.stab 3336 0
.stabstr 12791 0
.comment 54 0
.reset 0 0
Total 16917
Errors: none
-------- end --------
> Process Exit Code: 0
