Rally Computer
Mikat
Has thanked: 7 times
Been thanked: 36 times
Re: Rally Computer
Post by Mikat »
Benj wrote:
I didn't connect the reset pin on the lcd. You thinbk that maybe the problem?
I think you will probably have to at least connect the reset pin to the +ve power rail for the display to work, otherwise it may simply sit in reset mode.
Some models at KS108 displays are needs to connect the reset via 10Kohm at +5 v, and I test some display, the resistor need to be 10K, 1K didn't work...
Mika
stabmegane
Has thanked: 1 time
Re: Rally Computer
Post by stabmegane »
Never mind, i figured it out, i also added the reset pin as a variable and it 's working great now.
Thanks a lot for all your help.
stabmegane
Has thanked: 1 time
Re: Rally Computer
One more question,
Is it possible to make characters for the Glcd with a different resolution?
I mean make a character not 8x5 but 8x8 or somthing like this?
Thank you in advance
petesmart
Has thanked: 187 times
Been thanked: 140 times
Re: Rally Computer
Post by petesmart »
I have used an EB-057 with some success.. If you change the font from either 0,1,2,3 or 4 you will get a font size change.. Not sure if this helps...
Best regards
Pete
sorry about that Chief!
