V Drive 2 for data logger
Re: V Drive 2 for data logger
Hi Steve,
The errors are caused by a bug in the
16F18875.fcdx
file
The interrupt handler for timer2 is wrong.
Using PIE1 & PIR1 instead of PIE4 & PIR4
I have attached a corrected file.
If you replace existing file within \Flowcode 7\FCD\PIC directory, Hopefully should compile ok after you have reloaded flowchart.
16F18875.fcdx
(28.49 KiB) Downloaded 333 times
Steve001
Has thanked: 460 times
Been thanked: 523 times
Post by Steve001 »
Hi Martin
once again thank you, will have a go later and get back to you
No problem Steve.
Will await your feedback
Steve001
Post by Steve001 »
hi martin
Its programed, I cannot find my usb stick think I have left it at work :(
Steve001
Post by Steve001 »
Hi Martin
Neither example file as above that you posted writing to the usb, they work with my ecio40 the only thing I have changed is the target to PIC16F18875
http://www.matrixtsl.com/mmforums/viewt ... 176#p82483
or
http://www.matrixtsl.com/mmforums/viewt ... 176#p82485
No errors when programming
any ideas
Hi Steve,
You could use USB to serial converter.
Then use Tera Term in Debug mode to log check for correct data.
you can have USB to serial converter and Vdrive in parallel
Steve001
Post by Steve001 »
cheers martin will have a go with that
Steve001
Post by Steve001 »
Hi Martin,
Still no joy :( after reading a bit further in the data sheet Tx/CK (Pin 25 - C6) appears to be a mappable pin I have my vdrive connected to C6 nothing appears to be coming out. Had my scope on it. It's floating around 1mv
looking at page 9 of the data sheet Pin25 = CK, page 10 note3 says that you should map this with a PPS output register as per table 13.3 (page 247) :cry: :? :?
http://ww1.microchip.com/downloads/en/D ... 01802D.pdf
Hi Steve,
It looks like it maybe the components to do with UART that may need modifying?
Something similar was requested here.
Perhaps it can be added to the list.
As you started this topic and now using Flowcode V7 instead of V6, I have moved to a more appropriate section.
Steve001
Post by Steve001 »
Hi Martin,
Thank you, i will ask the question
Steve001
Post by Steve001 »
Hi Martin,
Can you have a go with this please ? not sure if I am having a airhead brain fart moment
I have the following pin assignments
TX - C6( Pin25)
RX - C1
I don't appear to get any data out of pin 25 have tried a scope, a serial adaptor used with PuTYy (used as a terminal)
http://www.putty.org/
Can you have a try just to make sure I am not being stupid
What is the voltage on C6?
If successfully been set up for UART then with not data present it should stay at 5V.
Are you using the the latest UART updates from here?
If not don't forget after adding updates to select the Reload icon.
Also you have Baud rate set at 9600. I set the Vdrive to 2400.
Steve001
Post by Steve001 »
Hi Martin
C6 floating around 1 - 2 mV
yes i applied those updates (I will try to apply them again)
the baud rate you modified my .FTD to 9600 here
viewtopic.php?f=68&t=17176&start=25#p82550
i dont think i have applied the RS232 fix in the post above bens i will download that and give it a whirl
:edit - no my RS232 file is a earlier revision (29.06.2017) will try it and let you know
Steve001
Post by Steve001 »
Hi martin,
re installed the updated files, had no joy so far will have another go tomorrow
