Can't Change Individual Ports
Posted: Wed Apr 04, 2012 2:42 pm
by rocket200
So I I need to display a number on one 7 segment display. There is one problem though. When I go into the Connections and try to change one Port Letter (i.e. PORTA, or PORTB) it changes EVERY port letter. I need to change segment A Port to PORTD 0 and segment B and up to ports PORTB 0 - PORTB 6. The reason I need to change segment A to a different port is because that port is being used by something else.
I'd really appreciate any help! Thank you!!!
Re: Can't Change Individual Ports
Posted: Wed Apr 04, 2012 3:50 pm
Ok this is possible but you cannot do it directly through the component without using code customization.
Select the component on the panel and click the custom code button.
Select the Show digit function and click edit.
Scroll down to the section beginning like this.
MX_7SEG1_COMMON_TRIS = MX_7SEG1_COMMON_TRIS & %o;
MX_7SEG1_SEGMENT_TRIS = MX_7SEG1_SEGMENT_TRIS & %p;
Edit it so that it matches your desired pin out. Basically you need to clear each bit in the tris register associated with the 8 outputs for the 7seg.
TRISD = TRISD & ~(0x01);
TRISB = TRISB & ~(0x7E);
Next find this section.
//common anode
MX_7SEG1_SEGMENT_PORT = (MX_7SEG1_SEGMENT_PORT & %p) | cSegmentValue;
MX_7SEG1_COMMON_PORT = (MX_7SEG1_COMMON_PORT | %n);
#else
//common cathode
MX_7SEG1_SEGMENT_PORT = (MX_7SEG1_SEGMENT_PORT & %p) | ~cSegmentValue;
MX_7SEG1_COMMON_PORT = (MX_7SEG1_COMMON_PORT & %o);
And change to this to route the data to the correct output pins.
//common anode
PORTD = (PORTD & 0xFE) | (cSegmentValue & 0x01);
cSegmentValue = cSegmentValue >> 1;
PORTB = (PORTB & 0x80) | (cSegmentValue & 0x7F);
#else
//common cathode
PORTD = (PORTD & 0xFE) | (~cSegmentValue & 0x01);
PORTB = (PORTB & 0x80) | (~cSegmentValue & 0x7F);
Click ok and then close and that's it your done.
Let me know how you get on.
Posted: Wed Apr 04, 2012 6:03 pm
by rocket200
Benj wrote:Hello,
//common anode
#else
//common cathode
//common anode
#else
//common cathode
My code looks a little different so I can't figure out where exactly to put the new code. Also, can you explain how the hex values correspond to the pin?
My code:
    //Segment Port Definitions
    #define MX_7SEG1_SEGMENT_PORT  PORT%a
    #define MX_7SEG1_SEGMENT_DDR  DDR%a
    //Common Port Definitions
    #define MX_7SEG1_COMMON_PORT   PORT%b
    #define MX_7SEG1_COMMON_DDR   DDR%b
    //set pattern array for the display
	const char cSegmentArray[] = {%c, %d, %e, %f, %g, %h, %i, %j, %k, %l};
	//get pattern for digit
	char cSegmentValue = cSegmentArray[Value % 10];
	if (DecimalPoint)
		cSegmentValue = cSegmentValue & %m;
	//set up ports
	MX_7SEG1_COMMON_DDR = MX_7SEG1_COMMON_DDR | ~%o;
	MX_7SEG1_SEGMENT_DDR = MX_7SEG1_SEGMENT_DDR | ~%p;
	//display the digit
    #if (%q == 1)
		//common anode
	#else
		//common cathode
	#endif
	//undefine symbols
    #undef MX_7SEG1_SEGMENT_PORT
    #undef MX_7SEG1_SEGMENT_DDR
    #undef MX_7SEG1_COMMON_PORT
    #undef MX_7SEG1_COMMON_DDR
Posted: Thu Apr 05, 2012 11:16 am
Aha your using AVR not PIC, sorry about that.
Ok this section.
//set up ports
Change to this.
DDRD = DDRD | 0x01;
DDRB = DDRB | 0x7E;
And this section.
//common anode
#else
//common cathode
Change to this.
//common anode
#else
//common cathode
Each Port register is made up of 8 bits. A hex value from 0x00 to 0xFF is an 8-bit value that contains all of the possible combinations of 0's and 1's, 256 different combinations to be precise and including 0.
This masks off the first data bit allowing us to write the bit0 of portd.
cSegmentValue >> 1
This shifts the variable cSegmentValue to the right by one place essentially dropping the least significant bit.
We then use 7F to mask off the remaining 7 bits of data to pass to portb.
Posted: Thu Apr 05, 2012 7:39 pm
by rocket200
Benj wrote:Aha your using AVR not PIC, sorry about that.
Ok this section.
//set up ports
Change to this.
DDRD = DDRD | 0x01;
DDRB = DDRB | 0x7E;
And this section.
//common anode
#else
//common cathode
Change to this.
//common anode
#else
//common cathode
cSegmentValue >> 1
So I actually need to change Segment D instead. I made all of your modifications with a couple changes to make it change to Segment D instead of A. So far, all the segments are working except for Segment D.
Here is the code:
//set up ports
	DDRB = DDRB | 0xF7;
	DDRD = DDRD | 0x01;
//common cathode
		PORTB = (PORTB & 0xFE) | (~cSegmentValue & 0x01);
		PORTB = (PORTB & 0xFD) | (~cSegmentValue & 0x02);
		PORTB = (PORTB & 0xFB) | (~cSegmentValue & 0x04);
		PORTD = (PORTD & 0xF7) | (~cSegmentValue & 0x08);
		PORTB = (PORTB & 0xEF) | (~cSegmentValue & 0x10);
		PORTB = (PORTB & 0xDF) | (~cSegmentValue & 0x20);
		PORTB = (PORTB & 0xBF) | (~cSegmentValue & 0x40);
		PORTB = (PORTB & 0x7F) | (~cSegmentValue & 0x80);
Thanks for all your help!
Posted: Tue Apr 10, 2012 9:42 am
I think this line of code.
Should look like this if you are using pin D0.
PORTD = (PORTD & 0xFE) | ((~cSegmentValue & 0x08) >> 3);
Posted: Tue Apr 10, 2012 7:08 pm
by rocket200
Benj wrote:Hello,
It works! Thank you!
Posted: Tue Jun 26, 2012 9:01 pm
by rocket200
Benj wrote:Hello,
Hello! Sorry to bring this thread back from the dead, but I have a problem.
Basically I got a new 7-segment display and it has common anodes instead of cathodes. Could you help me make the code for the common anodes instead of the cathodes? Same exact as the common cathodes setup except now they need to be anodes. I am guessing the ports and segments would need to be inverted so the electricity can flow into the ports instead of out? I can't figure this out so could I get your help? Thank you so very much!
Also, if it helps, here is a pinout of what I need:
SEGMENT A > PORTB.0
SEGMENT B > PORTB.1
SEGMENT C > PORTB.2
SEGMENT D > PORTD.0
SEGMENT E > PORTB.4
SEGMENT F > PORTB.5
SEGMENT G > PORTB.6
