Pic 16LF1906
Posted: Sat May 05, 2012 2:34 pm
by psf
Hi everybody. As usually I'm going to "complicate" my life with a new Pic I discovered: 16LF1906. Flowcode actually support 16LF1903 that is quite similar (1906 have double program memory and EUSART which I don't use). So I try to update the .fcd file (flowcode discovered the new component) but probably there should be problems with C compiler because if I compile an empty programs I get some errors:
Lcd2.c(68:2): error: unknown identifier 'ansela'
Lcd2.c(68:2): error: invalid operand 'ansela'
Lcd2.c(68:9): error: failed to generate expression
Lcd2.c(69:1): error: unknown identifier 'anselb'
Lcd2.c(69:1): error: invalid operand 'anselb'
Lcd2.c(69:8): error: failed to generate expression
Lcd2.c(73:2): error: unknown identifier 'option_reg'
Lcd2.c(73:2): error: invalid operand 'option_reg'
Lcd2.c(73:13): error: failed to generate expression
By the way if I compile empty program on 1903 everything OK.
Thanks in advance!
Re: Pic 16LF1906
Posted: Tue May 08, 2012 9:59 am
It looks like the 1906 device is not currently supported by the BoostC compiler packaged with Flowcode. Is it possible for you to use another device? Otherwise you may have better results using the HiTech compiler with this new device.
http://www.matrixmultimedia.com/mmforum ... =26&t=6812
Re: Pic 16LF1906
Posted: Tue May 08, 2012 10:07 am
by psf
I use 1906 just for program memory, and I already bought it. I can use the other C compiler if it's ok. But another way: can we just manage 1903 in order to create a program for 1906. I don't need the EUSART, just LCD driver and the double program memory.
Re: Pic 16LF1906
Posted: Tue May 08, 2012 4:56 pm
by Steve
I think if you use Flowcode to create a program for the 16LF1903, it has a good chance of working in the 16LF1906.
Re: Pic 16LF1906
Posted: Wed May 09, 2012 2:47 pm
by psf
So, installed HI tech c, but there is a problem with C icon:
e.g.
asm clrf _lcddata0
asm clrf _lcddata1
compiling with BOOSTC everything is ok but HItech tell me:
106: asm clrf _lcddata0
^ (317) "(" expected
^ (318) string expected
^ (194) ")" expected
^ (312) ";" expected
and so on, many many errors...
I try Steve method also. The 16LF1903 lib is defected: LCDSE3 register is missing (only in1903, 1906 that is quite the same is OK). By the way even HI TECH library has the same mistake, but fortunately can be resolved writing few words.
Thanks for help.
Re: Pic 16LF1906
Posted: Wed May 09, 2012 4:32 pm
I think for HiTech you have to do assembler code like this.
ASM("NOP");
Re: Pic 16LF1906
Posted: Wed May 09, 2012 5:23 pm
by psf
Benj wrote:Hello,
ASM("NOP");
Great!
BUT
Now HITECH discovered other 2 errors:
Lcd3.c: main()
1720: INT0IE = 1;
^ (192) undefined identifier "INT0IE"
Lcd3.c: myisr()
1848: if (ts_bit(INTCON, INT0IF) && ts_bit(INTCON, INT0IE))
^ (192) undefined identifier "INT0IF"
(192) undefined identifier "INT0IE" ^
The strange is that in c code generated by flowcode these parts are:
st_bit(intcon, INTE);
if (ts_bit(intcon, INTF) && ts_bit(intcon, INTE))
I can't understand if it's a problem of Flowcode or >>>>(HITECH)<<<<<; I have even modified the .h file in order to rename the 2 flags but it's a nonsense!
Re: Pic 16LF1906
Posted: Sat May 12, 2012 11:13 am
by psf
Hi guys, after hours I found out a solution, SOURCEBOOST released V7.05.1 that support 16LF1906, I installed the lite version just to make some experiment and it work perfectly without any mistake.
I hope it could be integrated in Flowcode because I read minor upgrades are free.
Just a more suggestion (only for reference /google index) Microchip data-sheet for 16LF1906 has many errors on LCD segment mapping worksheet page 201.
Last 3 (5 for 1607) segment 24/25/26 are not in LCDDATA2 (COM0) and LCDDATA5 (COM1) and so on BUT consider LCDDATA12 /LDCDATA15 ....
Also the BITS are wrong they aren't for example SEG26COM0 LCDDATA2,7 >>>>BUT>>>>>> LCDDATA12,2 and so on.
In the other section of data-sheet they are reported correctly but working on it the first time it's not so easy to debug this small problem.
Have a nice weekend!
Re: Pic 16LF1906
Posted: Sat May 12, 2012 3:09 pm
by dazz
thanks for the heads up ,it will save a lot of head scratching if someone else uses that chip
Re: Pic 16LF1906
Posted: Mon May 14, 2012 12:18 pm
Thanks for the update,
I will see if we can get an update for BoostC into the next update release so this is no longer an issue.
