LCD
Posted: Sun May 20, 2012 5:11 pm
16x2 character display with backlight. This display uses a frequently used HD44780 compatible controller.
i use flowcode in school(V3) and i have a pré-build LCD but when i try to use the lcd in flowcode i can not assign pins becaus its on two ports.
1 Vcc +5V
2 GND GND
3 V0 Trimmer TR1 Contrast adjustment
4 RS RE0 Register select: low = instruction, high = data
5 R/W RE1 Low = Write, High = Read
6 E RE2 Enable (active high)
7 DB0 RD0 Data-bus bit 0 (not used in 4-bit mode)
8 DB1 RD1 Data-bus bit 1 (not used in 4-bit mode)
9 DB2 RD2 Data-bus bit 2 (not used in 4-bit mode)
10 DB3 RD3 Data-bus bit 3 (not used in 4-bit mode)
11 DB4 RD4 Data-bus bit 4
12 DB5 RD5 Data-bus bit 5
13 DB6 RD6 Data-bus bit 6
14 DB7 RD7 Data-bus bit 7
15 LED+ +5V Positive backlight supply
16 LED- RC0 (through T1) Negative backlight supply
the port always changes so i can only choose port E or port B (and not both)
1 Vcc +5V
2 GND GND
