PIC 12LF1840 error
waligator
Has thanked: 5 times
Been thanked: 7 times
PIC 12LF1840 error
Post by waligator »
Hi all,
When I select the PIC 12LF1840, a message appears "Unknown Chiptype". And when I confirm the chip, another message "could not set selected chip".
Before I order this type of PIC, there will he a programming problem?
Can you help me?
In advance thank youAnnuler les modifications
Re: PIC 12LF1840 error
Have you tried compiling with 12F1840 instead?
If compiles OK, should work on your 12LF1840 device when it turns up.
waligator
Post by waligator »
Hello Martin,
Yes, I compiled and no errors.
I will order this type of PIC and test in real situations.
thank you
Your welcome,
Lets hope it all works OK.
I don't believe there will be any issues.
waligator
Post by waligator »
hello,
Well, I got the PIC and I could program it. Everything is ok.
These errors occur when I change the type of PIC in an existing program.
