Flowcode + MPLAB compile errors
Posted: Mon Jul 16, 2012 6:21 am
by chico
Hello -
There is something I don't understand about Flowcode. If I try to compile my Flowcode C source in MPLAB, some of the variables that Flowcode generates are too long for the Hi-Tech compiler to handle.
In the code below, the compiler gives "Conflicting Declaration" errors for different variables generated by Flowcode. For example, "//ADC(0): //Macro function declarations" contains:
void FCD_ADC0_SampleADC();
MX_UINT8 FCD_ADC0_ReadAsByte();
MX_UINT16 FCD_ADC0_ReadAsInt();
MX_FLOAT FCD_ADC0_ReadAsVoltage();
void FCD_ADC0_ReadAsString(MX_CHAR* FCR_RETVAL, MX_UINT8 FCR_RETVAL_SIZE);
void FCD_ADC0_ADC_RAW_Configure_Channel();
MX_UINT8 FCD_ADC0_ADC_RAW_Sample_Channel_Byte();
MX_UINT16 FCD_ADC0_ADC_RAW_Sample_Channel_Int();
MX_UINT8 FCD_ADC0_ADC_RAW_Average_Channel_Byte(MX_UINT8 NumSamples, MX_UINT8 DelayUs);
MX_UINT16 FCD_ADC0_ADC_RAW_Average_Channel_Int(MX_UINT8 NumSamples, MX_UINT8 DelayUs);
void FCD_ADC0_ADC_RAW_Disable_Channel();
…which causes the compiler to generate the following errors:
Build C:\MPLAB_Projects\Example_V5\Example_FCv5 for device 18F4431
Using driver C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18.exe
Make: The target "C:\MPLAB_Projects\Example_V5\Example_4431_V5.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18.exe" --pass1 C:\MPLAB_Projects\Example_V5\Example_4431_V5.c -q --chip=18F4431 -P --runtime=default --opt=default,+asm,-speed,+space,9 --warn=0 -D__DEBUG=1 -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error   [984] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 335.44 type redeclared
Error   [1098] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 335.44 conflicting declarations for variable "FCD_ADC0_ADC_RAW_Sample_Channel" (C:\MPLAB_Projects\Example_V5\Example_4431_V5.c:334)
Error   [984] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 337.81 type redeclared
Error   [1098] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 337.81 conflicting declarations for variable "FCD_ADC0_ADC_RAW_Average_Channe" (C:\MPLAB_Projects\Example_V5\Example_4431_V5.c:336)
Error   [984] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 557.1 type redeclared
Error   [1098] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 557.1 conflicting declarations for variable "FCD_ADC0_ADC_RAW_Sample_Channel" (C:\MPLAB_Projects\Example_V5\Example_4431_V5.c:550)
Error   [1098] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 557.1 conflicting declarations for variable "FCD_ADC0_ADC_RAW_Sample_Channel" (C:\MPLAB_Projects\Example_V5\Example_4431_V5.c:557)
Error   [984] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 583.1 type redeclared
Error   [1098] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 583.1 conflicting declarations for variable "FCD_ADC0_ADC_RAW_Average_Channe" (C:\MPLAB_Projects\Example_V5\Example_4431_V5.c:564)
Error   [1098] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 583.1 conflicting declarations for variable "FCD_ADC0_ADC_RAW_Average_Channe" (C:\MPLAB_Projects\Example_V5\Example_4431_V5.c:583)
Warning [359] C:\Program Files\Flowcode\v5\CAL\PIC\PIC_CAL_ADC.c; 1481.18 illegal conversion between pointer types
Warning [359] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 1145.40 illegal conversion between pointer types
Warning [359] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 1153.47 illegal conversion between pointer types
Warning [359] C:\MPLAB_Projects\Example_V5\Example_4431_V5.c; 1161.47 illegal conversion between pointer types
…..(no more errors, just warnings….)
Since these are generated by Flowcode and not by the user, how can the user get the compiler to recognize them as separate variables?
Re: Flowcode + MPLAB compile errors
Posted: Mon Jul 16, 2012 12:49 pm
It looks like these lines in the C file are to blame.
984
1098
Can you post up the C file and hopefully I can help to spot what's going wrong for you.
Posted: Mon Jul 16, 2012 5:55 pm
by chico
Benj wrote:Hello,
984
1098
Thanks for the response.
Actually, 984 and 1098 are the compiler error codes. The problem lines are listed at the end of the error messages in the HT compiler. So in this case, the problematic lines are 334, 335, 336, 336,557, and 583. The first three are definitions and the last two are routines:
334:  MX_UINT8 FCD_ADC0_ADC_RAW_Sample_Channel_Byte();
335:  MX_UINT16 FCD_ADC0_ADC_RAW_Sample_Channel_Int();
336:  MX_UINT8 FCD_ADC0_ADC_RAW_Average_Channel_Byte(MX_UINT8 NumSamples, MX_UINT8 DelayUs);
556:  MX_UINT16 FCD_ADC0_ADC_RAW_Sample_Channel_Int()
557:  {
558:
559:		return FC_CAL_Sample_ADC( 1 );	//Perform Sample - Return as MX_UINT16
560:
561:  }
582:  MX_UINT16 FCD_ADC0_ADC_RAW_Average_Channel_Int(MX_UINT8 NumSamples, MX_UINT8 DelayUs)
583:  {
584:
585:  		MX_UINT32 average = 0;
586:  		MX_UINT8 count;
587:
588:  		for (count=0; count<NumSamples; count++)
589:  		{
560:  			average = average + FC_CAL_Sample_ADC( 1 );					//Perform Sample - Return as MX_UINT16 - add to average
561:
562:  			if (DelayUs)
563:  				delay_us(DelayUs);										//If delay is not 0 then pause between samples
564:  		}
565:  		average = average / count;
566:
567:  		return (average & 0x1FFF);										//Return average as MX_SINT16
568:
569:  }
I'm not a compiler genius, but it seems to me that the compiler can't handle the long variable names. I've been examining the compiler manual but can't find the part that says how many characters are allowed for definitions.
Does it make sense to you? I saw another post that seemed to indicate a similar issue:
http://www.matrixmultimedia.com/mmforum ... NT8#p36856
Sorry to bother you but this problem will keep me from using Flowcode....
Posted: Mon Jul 16, 2012 7:01 pm
by kersing
Could you try adding -N 50 to the compiler command line? This should increase the number of significant characters in the identifiers from the default 31 characters to 50 characters. (reference)
Posted: Mon Jul 16, 2012 10:07 pm
by James johnson
kersing wrote:Could you try adding -N 50 to the compiler command line? This should increase the number of significant characters in the identifiers from the default 31 characters to 50 characters. (reference)
Ah, thank you for the reference. I hadn't been able to find that info before.
I found the MPLAB "Identifier Length" menu setting under: Project > Build Options > Compiler > (filename.c) > Identifier Length
...and it worked! Errors went away. Thanks for that.
NEXT ERROR (now that the compiler can proceed) is a linker error, "Unknown Record Type" (MX_FLOAT FCV_WATER_TEMP_VOLTAGE;):
Build C:\MPLAB_Projects\Example_V5\Example_FCv5 for device 18F2620
Make: The target "C:\MPLAB_Projects\Example_V5\Example_2620_V5.p1" is up to date.
Executing: "C:\Program Files\HI-TECH Software\PICC-18\PRO\9.63\bin\picc18.exe" -oExample_FCv5.cof -mExample_FCv5.map --summary=default,-psect,-class,+mem,-hex --output=default,-inhx032 Example_2620_V5.p1 "C:\Program Files\Flowcode\v5\Tools\boostc\Lib\float.pic18.lib" "C:\Program Files\Flowcode\v5\Tools\boostc\Lib\libc.pic18.lib" --chip=18F2620 -P --runtime=default,+clear,+init,-keep,-download,+stackwarn,-config,+clib,-plib --opt=default,+asm,-speed,+space,9 --warn=0 -N75 -D__DEBUG=1 -Blarge --double=24 --cp=16 -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
HI-TECH C PRO for the PIC18 MCU Family  V9.63PL3
Copyright (C) 1984-2009 HI-TECH SOFTWARE
this licence will expire on Wed, 12 Dec 2029
Advisory[1233] Employing 18F2620 errata work-arounds:
Advisory[1234]  * Corrupted fast interrupt shadow registers
Advisory[1234]  * Data in RAM location can be corrupted if async. reset occurs during write
Error   [380] ; . unknown record type (142)
********** Build failed! **********
From the Hi-Tech C manual:
(380) unknown record type (*) (Linker) This is an internal compiler error. Contact HI-TECH Software technical support with details.
The source error line (142):
140:  MX_UINT8 FCV_B2;
141:  MX_SINT16 FCV_WATER_TRANSIT_COUNT;
142:  MX_FLOAT FCV_WATER_TEMP_VOLTAGE;
143:  MX_UINT8 FCV_FCR_RETVAL;
144:  MX_CHAR FCV_TRANSFER_CURVE_STATUS[FCSZ_TRANSFER_CURVE_STATUS];
Any thoughts on this error? I'm not sure I understand how Flowcode defines these MX types...
Posted: Tue Jul 17, 2012 3:34 am
by James johnson
James johnson wrote: NEXT ERROR (now that the compiler can proceed) is a linker error, "Unknown Record Type" (MX_FLOAT FCV_WATER_TEMP_VOLTAGE;):
OK, I found the problem with this error. I had neglected to remove the Flowcode libraries necessary for compilation with BoostC. They aren't needed with Hi-Tech C. Doh!
Anyway, now I can compile my file inside of MPLAB with Hi-Tech v9.65 and v9.80 as well as BoostC.
Thanks for the help, everyone.
