GCLD print speed
Tony Brown
Has thanked: 36 times
Been thanked: 5 times
GCLD print speed
Post by Tony Brown »
I have got my GLCD to work in flowcode, but when it comes to printing anything on the screen it prints a letter at a time instead of all text instantly.
Anyone have any idea's
Re: GCLD print speed
Sounds like your micro is running pretty slowly or may be running at the incorrect speed.
What is your clock speed and have you confirmed the Flowcode clock speed in the project options matches the hardware clock speed by running a simple 1 second flasher test.
Also which gLCD are you using?
Tony Brown
Hi Benj
The GLCD i am using is a "MG1206E 128x64 dot glcd".
I am using a 4MHz xtal and flowcode reflex this, the only thing I found wrong was the setting were on HS instead of XT, which I have now changed but this has changed nothing.
Tony
Enamul
Has thanked: 271 times
Been thanked: 814 times
Post by Enamul »
Can you please post the screen shot of your config?
Enamul
Enamul
University of Nottingham
enamul4mm@gmail.com
Tony Brown
Hi Enamul
Please find attached the requested screen shot.
Thanks for your help
Tony
config screen shot.pdf
config screen shot
(47.81 KiB) Downloaded 265 times
Enamul
Post by Enamul »
Hi Tony,
Your config seems fine. It might be a code issue in that case. Can you kindly post your FC with custom c code so that we can dig out where it going wrong?
Enamul
Enamul
enamul4mm@gmail.com
Tony Brown
Hi Enamul
Glad to here my config is correct, thought it would be but nice to have a second opinion :D
Please find attached the requested FC custom file.
Tony
FC5_PIC_Custom.c
(22.01 KiB) Downloaded 269 times
Hi Tony,
Could the 4MHz crystal be the cause of the problems. Could you switch this for say a 20MHz crystal and get a 5 fold speed increase?
Another alternative which will give you more speed would be to edit this function in the custom C file.
void MX_LCD_Enable (void)
	set_bit(MX_CONTROL_PORT, MX_ENABLE);
	//delay_10us(1);								//Min delay 450ns
	nop();
	nop();
	nop();
	nop();
	nop();
	clear_bit(MX_CONTROL_PORT, MX_ENABLE);
	//delay_10us(1);								//Min delay 1.5us
	nop();
	nop();
	nop();
	nop();
	nop();
Simply removing some of the nop(); instructions will allow the program to throw data across to the display faster. I would first investigate upping the crystal value and then once this is working you can try playing around with the number of nop instructions to try and get even more speed.
Enamul
Post by Enamul »
Hi Tony,
I have just got option to see the c code and my opinion is same as Ben. If I were you I would try with delays in Enable macro as this is controlling write speed..
Enamul
Enamul
enamul4mm@gmail.com
Tony Brown
Thanks guys, just one more question, do I remove a nop() from both set bit and clear bit?
Thanks Tony
Hi Tony,
I don't think they have to be absolutely identical so you can probably remove from either side without too many ill effects. Best bet is to have a play and see what works.
The thing that will give you the most significant speed increase will be upgrading the crystal so be careful about removing all the nops and then trying with a faster crystal as this probably will require some if not all of the nops to be in place to allow the comms to work.
Tony Brown
Thank for advice, will be trying the 20MHz xtal first, hopefully this will solve my problem.
