new to flowcode
Posted: Mon Nov 26, 2012 6:19 pm
by phil..c
i have been using pic chips for quite a while for simple programs, now i'm starting to do more complex programming using flowcode. What i need to find out is does the flowcode software automatically assign weak pull ups to inputs that have not been assigned within the programming. for examlpe if i am using 2 inputs on port A and using 4 outputs on port B, will the flowcode just not assign anything to the port bits not used or will it assign port A input, Port B output and i have to pull the inputs down on the hardware ? My thoughts are that they are left un assigned and so it will be ok to be left un connected, Any help greatly appreciated. thank you
Re: new to flowcode
Posted: Mon Nov 26, 2012 6:40 pm
by Enamul
You can enable weak pull-up in Flowcode for un-used bits or you can do that in hardware..But in Flowcode that can be done only by using c code..which is PIC dependent..So if you tell us which PIC you are using we can tell you how to do that.
Re: new to flowcode
Posted: Tue Nov 27, 2012 8:09 am
by phil..c
thank you for the reply, I am not good with the 'C' programming code i used the lower level code as i understand that better, (but im by no means an expert!!!) The pic chip is 16f716 or 16c716. i am using the 16f for developing then when all is well the 16c. I really appreciate your help.
Re: new to flowcode
Posted: Tue Nov 27, 2012 9:44 am
by Enamul
No problem. The pic chip 16f716 has no soft-weak pull-up option for PORTA. It has pull up option for PORTB but not for individual PIN rather for whole PORTB. If you enable weak pull up and later on if you use PORTB as output; it will disable weak pull up. But if you have any unused pin in portb which is defined as input you will get pull-up feature there.
To enable weak pull up in portb, you have to add following line in the beginning of the code in c code box..
cr_bit(option_reg,7);
Re: new to flowcode
Posted: Tue Nov 27, 2012 10:24 am
by phil..c
thanks very much for the help, much appreciated
