Code Examples For Arduino??
Posted: Fri Dec 21, 2012 1:58 pm
by jchomley
Looking for code examples for UNO or Leonardo, all I can find are mainly examples for PIC?
Is there a repository I have overlooked? Dowloaded the example files etc.
Thanks in anticipation :-)
Re: Code Examples For Arduino??
Posted: Fri Dec 21, 2012 4:24 pm
by Enamul
Here might get some example for Arduino...
http://www.matrixmultimedia.com/mmforum ... ple#p37016
Posted: Fri Dec 21, 2012 5:08 pm
by dazz
If you want to use the examples in flowcode select import from the file menu, and change the chip to the arduino you are using, then move the component ports etc.
theres a thread that uses processing wiyh a pic but just change it to the arduino http://www.matrixmultimedia.com/mmforum ... ing#p36816
if you get stuck just holler
Dazz
