Servo on PIC18F87k22
Posted: Wed Mar 20, 2013 3:48 pm
by etillol
I'm experimenting the servo macros on my custom board based on PIC18F87k22.
I'm trying to drive a hobby servo on port RF7, but nothing moves.
I tried to drive this pin manually and I can make this servo move, though I'm asking myself if there is some restrictions for using the servo macro commands (must it be a capture compare pin or something)?
You can see in my attachement 2 files:
- servo.fcf does not work and uses servo macro commands
- servo_test.fcf is just toggling an output pin at the desired chronogramm to make the servo move between 2 positions.
If you have any idea that could explain why the servo macro commands cannot be used, I'll be happy to check tem.
Thank you,
Re: Servo on PIC18F87k22
Posted: Wed Mar 20, 2013 4:56 pm
by Dan81
Hello Etillol
I think there is a little bug in Flowcode.
If you put only 1 channel , it doesn't work.
Put 2 channels and it should be OK.
Daniel
Posted: Thu Mar 21, 2013 9:07 am
by etillol
Thank you for the tip but it doesn't work yet.
I took a look on the C code and it seems that the servo macros are based on interrupts on ccp1 (or ccp2) peripherals.
But I was wondering if it could use ccp peripheral to generate timings without using corresponding pins?
As I don't use this pins, it may explain why I don't have any pulse on RF7 pin.
What do you think of that?
void MX_INTERRUPT_MACRO(void)
	#ifndef MX_MIAC_SYSTEM
		if (ts_bit(pir1, CCP1IF) && ts_bit(pie1, CCP1IE))
			if (MX_SERVO_IDX < MX_SERVO_NO_CHAN)
				FCD_Servo0_TogglePort(MX_SERVO_PORT_ARRAY[MX_SERVO_IDX], MX_SERVO_PIN_ARRAY[MX_SERVO_IDX], 1);	//Start Servo duty cycle
				MX_SERVO_CALC = MX_SERVO_TRIM[MX_SERVO_IDX] + MX_SERVO_POSITION[MX_SERVO_IDX];		//Calculate the required position
				MX_SERVO_CALC = MX_SERVO_CALC * MX_SERVO_CLK_COUNT;									//Calculate the number of clock cycles required
				MX_SERVO_CALC = (MX_SERVO_CALC >> 8) & 0xFFFF;										//Shift back to be 16-bit
				ccpr2h = ( MX_SERVO_CALC >> 8 );			//Setup capture compare registers
				ccpr2l = ( MX_SERVO_CALC & 0xFF );
			cr_bit(pir1, CCP1IF);							//Clear interrupt
		if (ts_bit(pir2, CCP2IF) && ts_bit(pie2, CCP2IE))
			if (MX_SERVO_IDX < MX_SERVO_NO_CHAN)			//If channel is active
				FCD_Servo0_TogglePort(MX_SERVO_PORT_ARRAY[MX_SERVO_IDX], MX_SERVO_PIN_ARRAY[MX_SERVO_IDX],0);	//End of control pulse
			MX_SERVO_IDX = (MX_SERVO_IDX + 1) & 0x07;		//Increment channel
			if (MX_SERVO_REQUIRED[MX_SERVO_IDX] > MX_SERVO_POSITION[MX_SERVO_IDX])
				MX_SERVO_POSITION[MX_SERVO_IDX] = MX_SERVO_POSITION[MX_SERVO_IDX] + 1;	//Increment duty
			if (MX_SERVO_REQUIRED[MX_SERVO_IDX] < MX_SERVO_POSITION[MX_SERVO_IDX])
				MX_SERVO_POSITION[MX_SERVO_IDX] = MX_SERVO_POSITION[MX_SERVO_IDX] - 1;	//Decrement duty
			cr_bit(pir2, CCP2IF);							//Clear interrupt
	#endif
I also suspect some config bits that could interfere with CCP peripherals, but it's just an intuition.
