Making a simple HTTP POST with EB-023
milea
Flowcode V4 User
Post by milea »
I'm trying to make simple HTTP command ''POST'' but with no success.
I use format:
POST /page.php HTTP/1.1/r/n
HOST: mypage.com /r/n
Content-Type: application/x-www-form-urlencoded/r/n
/r/n
var1=1&var2=2&var3=3
I'm working with EB-023 internet board (with old W3100A ).
I use TCP_IP component Initialization->Create_TCP_Socket->TCP_Connect->(Sending HTML -> Tx_Start, Tx_SendByte->Tx_End).
Is this way is correct?
Please help me.
Kind regards
Mile
Has thanked: 481 times
Been thanked: 699 times
Re: Making a simple HTTP POST with EB-023
line terminators should be \r\n not /r/n
rgds
Leigh
milea
Flowcode V4 User
Post by milea »
Ok thanks, /r/n but actually I’m sending CRLF -> Chr(13)Chr(10) so that is not problem. I’m asking the all flow process for POSTing.
Kind regards
Mile
Ah right, OK. Yes the flow looks OK. You will need to listen for a reply.
Are you connecting with your own local server? As you will need to setup the IP addresses accordingly. The TCP component won’t do the DNS lookup for you.
milea
Flowcode V4 User
Post by milea »
I 'm conecting with remote web server, with fixed ip. Could you explained the whole process step by step ?
Kind regards
Mile
using the TCP/IP component:
Initialize
Create_TCP_Socket
TCP_Connect
Send the request (Tx_start, Tx_sendbyte, Tx_end)
Loop waiting reply
Ready = Rx_data_available
Delay 500ms
If Ready <> 0 {Read the data (Rx_readbyte)}
milea
Flowcode V4 User
Post by milea »
Thank you Leigh , it helps me.
Kind regards
