I2C timing
Posted: Sun Mar 24, 2013 9:38 pm
by ylanchec
I am using flowcode v5 on a pic16f1827.
I have a xtal running a 24Mhz and i have set i2c speed to 1Mhz, but i get this : (clock is a 250Kz instead of 1Mhz)
SCL :
CLOCK
(12.56 KiB) Downloaded 2268 times
SDA :
DATA
(10.9 KiB) Downloaded 2268 times
My other problem is the time beetween two frames : i have 2.4ms but i haven't any delay in my software. So how to reduce this time ?.
I2C
(17.07 KiB) Downloaded 993 times
Best regards
ylanchec
Re: I2C timing
Posted: Mon Mar 25, 2013 4:51 pm
by ylanchec
I have found the problem, there was a bug in PIC_CAL_I2C.C on sppadd register.
I have several computers and i have forget to update one of them.
This problem is corrected in 5.5 version.
I have also see the delay between data frames, i have to modify this file to reduce it.
Is it possible to make this configurable in the component box ?
Best regards.
ylanchec
