Change of values
jbs4wd
Has thanked: 4 times
Change of values
Post by jbs4wd »
I am trying set up a function that when for example P1 is set to 200 within the program via a user setting function., it stays there when unit is turned of and then back on. I am using a 16F690. How can I do this please.
Cheers
JOHN
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Change of values
Post by kersing »
Store the value in EEPROM. Read it at startup of the program and write a new value when it is provided by the user. Use an additional byte of EEPROM storage with a special value to indicate there is a stored value to prevent using uninitialized EEPROM data the first time your program runs.
In these messages a similar problem is addressed.
― C.S. Lewis
jbs4wd
Post by jbs4wd »
Thank you. That kicked the thought bubble into action
John
