Error when compiling V4 program on V6
mimiyum
Post by mimiyum »
I tried to open my v4 program on the V6. It simulates fine and looks like there's no problem. So, I saved it on V6 and compiled. I got the following error:
Errors when generating C source code:
LED B - with switch new test.c : 181 : error : Syntax error
LED B - with switch new test.c : 191 : error : Syntax error
LED B - with switch new test.c : 301 : error : Syntax error
LED B - with switch new test.c : 311 : error : Syntax error
Is there any simple solution to this?
Re: Error when compiling V4 program on V6
Is it possible for you to attach your program or send to me via a PM and I will take a look for you.
