I2C Display - Fails to compile
Posted: Sun Oct 12, 2014 10:44 pm
After updating to 6.1 I chose to have a go at using the I2C display component which I have been looking to play with for some time.
Device is a 18F4550
So just to start easy I added a 1s tick on a led (that works fine on its own) and downloaded it to hardware and all is ok.
However every time I add the compo0nent to the dashboard, set the I2C component to use RB0/RB1 (Channel 1) and the address to 0x40 and 2x16 I get this during preprocessing and that is where it fails.
Is there something obvious I am missing here in configuring this component ? Set I2C type, Address, start, clear and sand strings should be all that is needed ?
Any help greatly appreciated
John
Device is a 18F4550
SW_LCD_RLY_V61.c
Starting preprocessor: D:\FC6\compilers\pic\boostc\pp.exe SW_LCD_RLY_V61.c -i D:\FC6\compilers\pic\boostc\include -d _PIC18F4550 -la -c2 -o SW_LCD_RLY_V61.pp -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(468:2): error: unknown identifier 'sspcon3'
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(468:2): error: invalid operand 'sspcon3'
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(468:10): error: failed to generate expression
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(469:2): error: unknown identifier 'sspmsk'
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(469:2): error: invalid operand 'sspmsk'
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(469:9): error: failed to generate expression
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(543:8): error: unknown identifier 'sspcon3'
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(543:8): error: failed to generate expression
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(543:8): error: invalid operand 'sspcon3'
D:\FC6\CAL\PIC\PIC_CAL_I2C.c(543:17): error: failed to generate expression
SW_LCD_RLY_V61.c success
failure
Completed BoostC compilation, return = 1
D:\FC6\compilers\pic\boostc\boostc_18F.exe reported error code 1
John
