Timer interrupt in component code generation error
Posted: Thu Nov 20, 2014 12:05 am
When using a timer (Timer1) in a component the code generation fails. The code for the macro is generated as expected:
However the interrupt block generated calls the macro as if in the main flowchart:
void FCD_06431_udpipstack1__TimerTick()
Use :Interrupt
//Handler code for [TMR1]
#ifndef MX_ISR_T1
#define MX_ISR_T1
void _ISR _T1Interrupt(void)
IFS0bits.T1IF = 0;
FCM_TimerTick();
#else
#warning "This interrupt has previously been enabled, so the macro <TimerTick> may never get called."
#endif
