SOLVED: Error code 1: unknown identifier 'FCM . . .
Posted: Mon Nov 30, 2015 4:41 am
by bvolken
Okay, I've battled a lot of stuff getting this to work.
Target: PIC18F4580
Programmer: PICKIT3
OS: Windows 10 home 64 bit
FlowCode 6.1.2.0 (11.05.2015)
I got the PICKIT3 to work. I solved the Low Voltage Programming problem, I cracked the OSSCON setting requirement.
I tested some code to write 16 consecutive bytes to a 2x16 serial LCD display. Worked fine when I had it all in the "Main" macro.
So, I broke each 'subroutine' into individual macros in preparation to make a component.
Same stuff that I had working all in "main", but now throws a compiler error (error code 1)
Macro names have no spaces. None of these macros take or return any parameters. The only variable is a UINT 'counter'
This seems pretty basic to me, but I'm tired of scouring the internet for hints.
Thanks in advance.
Error:
LCD_Serial.c(230:2): error: unknown identifier 'FCM_LCD_Init'
LCD_Serial.c(230:2): error: failed to generate expression
LCD_Serial.c success
failure
Completed BoostC compilation, return = 1
C:\Program Files (x86)\Flowcode 6\compilers\pic\boostc\boostc_18F.exe reported error code 1
Re: Error code 1: unknown identifier 'FCM . . .
Posted: Mon Nov 30, 2015 1:43 pm
Please could you attach your Flowcode project file and I will investigate this problem for you. From what your saying it sounds like it should be fairly simple and should be working.
Re: SOLVED: Error code 1: unknown identifier 'FCM . . .
Posted: Mon Nov 30, 2015 7:12 pm
by bvolken
Here is the (self created) problem and solution.
The key was when I said "preparation to make a component".
While experimenting, I set the macros as "Embedded Macros" in the Interface Manager.
After watching a few more YouTube videos, I tried switching the macros to "Downloadable Macro" and everything compiled, downloaded and worked as desired.
To quote Homer: "D'oh"
Not sure what the problem was, specifically, I just know what fixed it.
Posted: Tue Dec 01, 2015 6:40 pm
Ok thanks for letting us know what the cause was.
Embedded is slightly different to downloadable in that you can make it call code without adding to the call stack, we use it quite a lot in the DSP components to avoid subroutine slowdown when reading or writing the buffers but it's fairly complicated.
I would say that in most cases when making components you either want downloadable, simulation or hidden.
