Switch to next pattern not working
Posted: Tue Mar 15, 2016 7:23 pm
by Frank607
I have made a program for flashing LEDs. In this program is also a fade in / fade out pattern.
If I push the button then starts pattern 1. The next push on the button will start pattern 2 with the fade in / fade out pattern. This all works good.
But when I’m in pattern 2 and push the button to go to pattern 3 it will not go to pattern 3.
Attached is the Flowcode program. Hopefully someone can help me.
Kind regards,
Frank
Re: Switch to next pattern not working
Posted: Tue Mar 15, 2016 8:46 pm
Hi Frank,
The issue is you have a loop within RampDown macro:
LED_Brightness > RampDown.RampTo
.RampTo is a local variable and since not set will be = 0
Because LED_Brightness will always be greater then RampDown macro will never be exited (same for RampUp macro).
Therefore LED pattern will always be due to timer interrupt.
Hope that helps
