7 Segment Compile Error on Arduino Uno
AbeFM
Has thanked: 2 times
Post by AbeFM »
I'm pretty new to FlowCode, though I have so far been able to do everything I want without any big issues.
Running through a quick test, I wanted to use the 7 segment display output. There's a couple issues, which may be a root cause, but here's the short version - I get compile errors for undefined functions.
Target folder: C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice
Source name:   C:\Users\Abe\Google Drive\Arduino\FlowCode\Practice\CounterTest.fcfx
Title:
Description:
Device:        AVR.ATMEGA.ATMEGA328P
Generated by:  Flowcode v6.1.3.2
Date:          Saturday, June 04, 2016 12:10:21
Users:         0
Registered to: 32649934
Licence key:   Z82HUT
   NOT FOR COMMERCIAL USE
http://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Flowcode 6\compilers\avr\batchfiles\avra.bat  atmega328p "C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.elf" "C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c" "C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.lst"
Launching compiler...
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice>"C:\PROGRA~2\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega328p -Os -funsigned-char -o "C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.elf" "C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c" -lm
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c: In function 'FCD_0d511_LED_7Seg1__ClearDigit':
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c:109: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c:109: error: (Each undeclared identifier is reported only once
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c:109: error: for each function it appears in.)
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c:109: error: 'FCP_PORT_A' undeclared (first use in this function)
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c: In function 'FCD_0d511_LED_7Seg1__ShowDigit':
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c:161: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\Abe\GOOGLE~1\Arduino\FlowCode\Practice\CounterTest.c:161: error: 'FCP_PORT_A' undeclared (first use in this function)
C:\Program Files (x86)\Flowcode 6\compilers\avr\batchfiles\avra.bat reported error code 1
FINISHED
Then again, it uses Port B for its output, and portB doesn't have 8 pins on an UNO. I can manually run the display with portA, but not with the component macro.
Am I doing something wrong? Is there a reasonable work-around? I don't really need this functionality (I hope it's clear my garbage code was just to test come features).
Final note: It won't compile if the functions (disabled or not) are in the program. It would be better if you didn't have to DELETE something but could just disable it to see if it's the problem. Is there some way to do this?
Thanks!!!!
CounterTest.fcfx
(6.4 KiB) Downloaded 288 times
Re: 7 Segment Compile Error on Arduino Uno
Hi AbeFM,
Errors like that usually occur when a pin is assigned to a pin which does not exist on hardware.
Looking at flowchart the issue would be with Common Pin
PortA0 does not exist with your current target, so perhaps you can chenge it to PortD0 for example.
AbeFM
Post by AbeFM »
Thanks Martin! I thought disabling the icon would do it. Changing the port as you said worked.
Is there some option to keep it from putting in includes for commented out items?
