A small but I think useful addition I believe. Would it be possible to choose the package of the chip within chip view. All the chips I use default to DIL but I tend to use TQFP44 chips a lot and its a pain to keep cross referencing the datasheet to find where a pin in the DIL package sits on an alternative package - particularly when I'm laying out a PCB.
Thanks for a brilliant product BTW
Alternative Chip View
- Has thanked: 16 times
- Been thanked: 18 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Re: Alternative Chip View
I like this ideaanzacinexile wrote:A small but I think useful addition I believe. Would it be possible to choose the package of the chip within chip view.
+1 here
Regards QMESAR
Regards QMESAR
This is a good idea, I've put it on the list as something to investigate.
There is a way of doing this now but it's a bit of a manual process.
First go into the "Flowcode 7/FCD" directory and into the chip family you're interested in changing. e.g. "C:\Program Files (x86)\Flowcode 7\FCD\PIC"
Copy the chip definition file you wish to edit to your desktop.
Using a text editor such as Textpad or Notepad++ open the .fcdx file on the desktop.
Scroll down until you find the section starting with "<pins"
For example this is the 16F1937 <pins section.
Move the pins around so they match the surface mount chip layout and save the file. The new section might look something like this.
Save the file and then copy back to the original location. Remember to take a backup of the original file just in case anything goes wrong.
<pins sides='2' smd='0' >
<pin name='MCLR/RE3/VPP' port='4' bit='3' />
<pin name='RA0/AN0/SS' port='0' bit='0' adc='0' />
<pin name='RA1/AN1' port='0' bit='1' adc='1' />
<pin name='RA2/AN2' port='0' bit='2' adc='2' />
<pin name='RA3/AN3/VREF' port='0' bit='3' adc='3' />
<pin name='RA4/T0CKI' port='0' bit='4' />
<pin name='RA5/AN4/SS' port='0' bit='5' adc='4' />
<pin name='RE0/AN5' port='4' bit='0' adc='5' />
<pin name='RE1/AN6' port='4' bit='1' adc='6' />
<pin name='RE2/AN7' port='4' bit='2' adc='7' />
<pin name='VDD' />
<pin name='VSS' />
<pin name='RA7/OSC1/CLKIN' port='0' bit='7' />
<pin name='RA6/OSC2/CLKOUT' port='0' bit='6' />
<pin name='RC0/T1OSO/T1CKI' port='2' bit='0' />
<pin name='RC1/T1OSI/CCP2' port='2' bit='1' />
<pin name='RC2/CCP1' port='2' bit='2' />
<pin name='RC3/SCK/SCL' port='2' bit='3' />
<pin name='RD0' port='3' bit='0' />
<pin name='RD1' port='3' bit='1' />
<pin name='RD2' port='3' bit='2' />
<pin name='RD3' port='3' bit='3' />
<pin name='RC4/SDI/SDA' port='2' bit='4' />
<pin name='RC5/SDO' port='2' bit='5' />
<pin name='RC6/TX/CK' port='2' bit='6' />
<pin name='RC7/RX/DT' port='2' bit='7' />
<pin name='RD4' port='3' bit='4' />
<pin name='RD5' port='3' bit='5' />
<pin name='RD6' port='3' bit='6' />
<pin name='RD7' port='3' bit='7' />
<pin name='VSS' />
<pin name='VDD' />
<pin name='RB0/AN12/INT' port='1' bit='0' adc='12' />
<pin name='RB1/AN10' port='1' bit='1' adc='10' />
<pin name='RB2/AN8' port='1' bit='2' adc='8' />
<pin name='RB3/AN9/CCP2' port='1' bit='3' adc='9' />
<pin name='RB4/AN11' port='1' bit='4' adc='11' />
<pin name='RB5/AN13' port='1' bit='5' adc='13' />
<pin name='RB6/PGC' port='1' bit='6' />
<pin name='RB7/PGD' port='1' bit='7' />
</pins>
<pins sides='4' smd='1' >
<pin name='VSS' />
<pin name='VDD' />
<pin name='VDD' />
<pin name='NC' />
<pin name='VDD' />
<pin name='NC' />
<pin name='VSS' />
<pin name='VSS' />
</pins>
