I have a Pic 18LF1622. It's working fine to write date with a sectorsize (512Byte)buffer from the FAT.
So what I need is one(or two) buffer more. So I can write in buffer A new date and on the same time write buffer B to the disk (maybe copy to Fatbuffer).
FC7 let me not create a buffer with 512Byte.
7567: (1250) could not find space (512 bytes) for variable _buffera
But FC7 let me just create 4 buffer's with 256Byte.
So it's not a problem of Dataspace. Is ther a way to go to 512byte?
Pic 18LF1622 buffer sd-card
- Has thanked: 182 times
- Been thanked: 179 times
Re: Pic 18LF1622 buffer sd-card
The compiler might be struggling to find a single block that is large enough.
You could instead break the 512 byte buffer up into 256 bytes.
If the index to the buffer is < 256 then use the first half buffer, otherwise use the second half buffer. This is how the 512 byte buffer inside the FAT component is done.
Could you use the buffer inside the component at all to save you creating two 512 byte buffers?
Extended file names are something I've been meaning to tackle for a while but they are not that straight forward and potentially add a lot of overhead to the component.
I'll add it to the list to have another investigation on how easy it would be to add support for them.
Oh Thank you Ben
I have a wish more ....
Write to the first block before I close the file. I need it to write in the fileheader
- how many block there is in the recorded file(data)
-start and stop time
