Problem with Error compiling board Arduino
Posted: Tue Jan 31, 2017 12:00 pm
HI everbody
Arduino compatible with MAC Type: MI5466.
I have problem with Error compiling board Arduino. “Sketch” / “Include Library” = show "Matrix MIAC" its OK
But I can not find the Board for Arduino with MAC in Tools “Matrix MIAC ATmega”
Please see: Error_Messages:
can not Finde "bord"
Do you have a solution to problemmet with "Board".
Want to help with solving the problem?
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega1280"
Build options changed, rebuilding all
Sketch uses 4148 bytes (3%) of program storage space. Maximum is 126976 bytes.
Global variables use 66 bytes (0%) of dynamic memory, leaving 8126 bytes for local variables. Maximum is 8192 bytes.
avrdude: Expected signature for ATmega1280 is 1E 97 03
Double check chip, or use -F to override this check.
Wrong microcontroller found. Did you select the right board from the Tools > Board menu?
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
