HI everbody
How to write codes for print degree symbol "°" to diaplay in MIAC (Arduino) type MI5466?
Print degree symbol "°" on Miac (Arduino)
- Has thanked: 17 times
- Been thanked: 46 times
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Print degree symbol "°" on Miac (Arduino)
Hi Monie,
I don't think there are currently many symbols in the font table. I will have a look at adding this next week.
Or you could add your own symbol into the font table in the MIAC FCD file in the case of Flowcode, or the header file in the Arduino library.
For Flowcode another alternative is to use the bitmap component.
Leigh
Leigh
- LeighM
Hi Monie,
Attached is an updated package for the MIAC Arduino that will give you the degree symbol.
The only two files that have changed are miac.cpp and font610.h, so you could just extract and overwrite these two in your Arduino installation.
If you also need this for Flowcode let me know and I'll try and get that updated sooner rather than later.
Leigh
Leigh
- Arduino IDE MIAC Library and Examples.zip
- (19.71 KiB) Downloaded 452 times
Hi LeighM
Many, many thanks ...
Degrees sympolet works fine.
Best Regard
Monie
Monie
