I was wandering if it is possible to have a function to use regular expressions in Flowcode
to be able to search in a string variable or text and output a string according to the regular expression .
Example : Outputstring = "REGEX" (Inputstring)
Regular Expressions
Re: Regular Expressions
hi LeighM
Well it's true that the Regex function will take a considerable amount of target space
but trying to construct code that for example output's what's between this & that
will still take space from target + more time , with regex is simply done by using (?<=this).*?(?=that)
in only one line of code .
I understand that it mite not be a good idea to use this function on targets with less than 4k of flash but, for the rest especially devices like STM32 should not be a problem .
In my opinion this function will make Flowcode much more powerful and attractive .
Maybe a more simple solution to this is a component since Regex library's
can be found all over the place
Here is one for Arduino : https://forum.arduino.cc/index.php?topic=59917.0
Also Attached as File
- Regexp.zip
- (15.26 KiB) Downloaded 280 times
