PIC18F25K22 Internal clock config...
Posted: Tue Apr 04, 2017 1:57 pm
by saakis
Hello Matrix and forum people!
Help me with config file for the pic 18f25k22. I want the internal oscillator 4x PLL and 16 MHz osc. So far I couldn't manage to do that... Give me a solution please!!!
Thank you!
Sakis
Re: PIC18F25K22 Internal clock config...
Posted: Tue Apr 04, 2017 2:17 pm
Hello Sakis,
Hopefully this should run as expected, let us know how you get on.
18F25K22.fcfx
(7.87 KiB) Downloaded 420 times
Posted: Tue Apr 04, 2017 3:17 pm
by saakis
Thank you for your reply Benj but it doesn't work. First didn't complete the compilation because the osccon was in capital letters(!). After that just bring the first word 0x55 and stop there. I tried to change some parameters from the config but no success...
Sakis
Posted: Tue Apr 04, 2017 3:32 pm
Sorry the register name was in v7 upper case format, v6 and earlier require lower case register names.
Might be worth waiting a while, sounds like the device is running a lot slower than expected and hence the 1 second delay is taking many multiples of 1 second.
Try adding this to your C code after the osccon line to try and force the PLL to be enabled. You might also need to change the PLL config setting to disabled as it looks like the PLL and INTOSC can only be enabled via the osctune register.
osctune = 0x40;  //Enable PLL
while ((osccon2 & 0x80) == 0);  //Wait for PLL to become stable
Let us know how you get on.
Posted: Tue Apr 04, 2017 3:59 pm
by saakis
Hi benj,
doing the config below, I have 4 sec pulce but changing the osccon to 70 it stucks. I need 4 times faster pulses. Maybe the PLL is not enabled...
Sakis
Posted: Tue Apr 04, 2017 4:25 pm
Maybe try enabling the Internal/External Oscillator Switchover config setting, I seem to remember this helping on another device.
Posted: Tue Apr 04, 2017 5:33 pm
by saakis
Hi Benj, still refuse to work...any other idea or I will use a crystal?
Posted: Tue Apr 04, 2017 5:42 pm
Hello Sakis,
There will be a way to do it, the datasheet says it can be done.
I would have a thorough read of section 2 of the datasheet and see if you can pull out any pearls of wisdom. Googling for example code can also be a good way.
Posted: Wed Apr 05, 2017 10:49 pm
by saakis
Hi Benj,
finally it works.The only problem I have is that if I enable both A6 & A7 as I/O the prossesor stuck after 1 sec. If the A6 is configured as a Clockout port the PIC is fine...One I/O less!
Thank you for your help!
