Regardning NUCLEO-F746ZG
I just made a test routine to turn all ports on and off
It works great for ports A,B,C,D,E
but there is no reaction on ports F & G
I suspect something with Flowcode, unless I made something wrong,
Bits C8, C9,C14, C15 , D8, D9 are also missing but manual indictates that these bits are used internally
Can they be made available with some configuration ?
Best regards
BO
NUCLEO-F746ZG , PORT F,G missing
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: NUCLEO-F746ZG , PORT F,G missing
Please try the attached updated FCD file, it will fix the operation of port F and G.
As for the missing pins, for now you could add the ones you want to this FCD.
- 32F746Nucleo144.fcdx
- (41.6 KiB) Downloaded 466 times
