Checking Variables
jollybv
Flowcode v5 User
Has thanked: 81 times
Been thanked: 25 times
Checking Variables
Post by jollybv »
Hi Guys
Not sure what is the correct way to do this. I have a variable called Key and a variable called Occupant now what i want is to say if key is > then 1 or key is < than (Occupant + 1) then proceed. I have tried the following key > 0 && Key < (Occupant + 1) key > 0 AND Key < (Occupant + 1) key > 0 OR Key < (Occupant + 1) but not sure which is the best way to do this
Re: Checking Variables
Hi Brian,
You will need to use two pipes (|| ) :
(5.48 KiB) Downloaded 2451 times
Which mean logical OR
So you use
If: (Key >1) || (key < (Occupant + 1))
Best to separate expressions with brackets.
Note:
|| = OR
&& = AND
! - NOT
You may already know this, but you are able to your variables to the simulation debugger watch window ,so you can check everything is working as expected.
I have explained how to do that in FC6 here.
Its exactly the same method for Flowcode V7
Just curious, but that statement only be false when Key = 1 and Occupant = 0
Is that what you're after?
jollybv
Flowcode v5 User
Post by jollybv »
Hi Martian
Thanks for the replay what I'm looking for is if the variable is between 1 & whatever i set the Occupant variable
Hi Brian
jollybv wrote:if the variable is between 1 & whatever i set the Occupant variable
Sorry I was taking this as a literal expression :
jollybv wrote: if key is > then 1 or key is < than (Occupant + 1) then proceed.
All you need to do is use AND (&&) instead of OR.
So:
(Key >= 1) && (key <= Occupant)
jollybv
Flowcode v5 User
Post by jollybv »
Hi Martin
Thanks again yes that makes sens to me now
