Error problem with HID after update since 7.2.1 *SOLVED!*
gonzogonzo
Has thanked: 18 times
Been thanked: 17 times
Post by gonzogonzo »
after download and install "Update since 7.2.1" compiling my project i receive this error:
Copyright (C) 2017 Microchip Technology Inc.
Employing 18F2550 errata work-arounds:
* Corrupted fast interrupt shadow registers
nrf2401RX.c:
191: #include "../../../CAL/PIC/USB/MX_usb_hid_ep0Out.c"
^ (141) can't open include file "../../../CAL/PIC/USB/MX_usb_hid_ep0Out.c": No such file or directory
(908) exit status = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic\bin\xc8.exe ha riportato il codice di errore 1
TERMINATO
Before update i not receive error but USB HID don't work.
nrf2401RX.fcfx
This is the file
(29.38 KiB) Downloaded 242 times
Any idea?
Re: Error problem with HID after update since 7.2.1
I believe we are discussing a similar issue here.
www.flowcode.co.uk/mmforums/viewtopic.php?f=68&t=19084
I'm looking into the problem.
gonzogonzo
Hello Benj,
yes it is exactly same problem; i hope that You can find solution at this.
The problem should now be fixed by applying the latest updates here.
viewtopic.php?f=63&t=18760
Let us know how you get on.
gonzogonzo
Hi Benj,
now, with new patch, compiling and HID work ok.
I suggest that You change name to patch because has old name and this can generate a little confusion.
Thanks very much.
