Compiler options settings locked
Posted: Thu Sep 07, 2017 6:57 pm
by Quartz
I am trying to point the compiler options window to all 3 of my Pro versions of the XC compilers.
However, I can open the compiler option window and..
I can create a new setting and save it but no matter what setting I select I can't change the compiler location or the parameters.
In the compiler options window I can use most of the items on it except change the location, parameters or use the browse button.
I have even exported a setting, changed the location in the saved file and then imported it (which works) but then it doesn't remember it or use it.
If I move off the setting and then go back it is back to default again....
Infact no matter what settings I select they all show' $(appdir)compilers\pic\bin\xc8.exe' in the location. Even the ARM ones....
Something is not right...
Can anyone shed any light onto this.
Please...
Re: Compiler options settings locked
Posted: Fri Sep 08, 2017 9:43 am
What target device do you have selected? Some target devices provide compiler option overrides in the definition file which could explain the problems you're seeing.
Posted: Sat Sep 09, 2017 11:02 am
by Quartz
Brilliant, just that alone sorted me out!
I was trying to build on the Curiosity board stuff and after reading your reply I changed the selected chip and I can now edit the location etc...
Found what I need to do now many thanks for your help.... Again.
